OH1KK
OH1KK
19
11
  • I spotted Radio France Internationale transmitting DRM on 15300kHz. Spotted monday 5.4.2021 14.57.56 +0300 http://forum.kiwisdr.com/uploads/458/5U2KEIMZZT4Y.png https://www.bclnews.it/2021/03/22/a21-schedule-radio-france-international-drm/
    in DRM Heard Comment by OH1KK April 2021
  • Fix. On ant_switch.js file line 22 you need to change  var firstChars = getFirstChars(data, 3); to  var firstChars = arrayBufferToStringLen(data, 3); and then make stop make make install make start I updated my github repo. Should work with v1…
  • I haven't tried in real life, but it looks that gpio pin control is easy on beaglebone. Converting ms-s7-web script to use beaglebone gpio pins should be trivial. My KiwiSDR is offsite and on production state and it has also working antenna switch. …
  • Antenna switches by schedule. My KiwiSDR extension has script /usr/local/bin/ms-s7-web which commands ms-s7-web antenna switch from linux console. It can be used to schedule antenna switching via KiwiSDR's crontab. Just edit KiwiSDR's /etc/crontab …
  • >After you run 'make' is ant_switch listed in Beagle_SDR_GPS/extensions/ext_init.c ? Yes. >If you run the server from the command line is ant_switch listed in the extensions registered list? No. > In ant_switch_main() is the call to e…
  • I though that my GPS was broken. Then I figured out that KiwiSDR searches (acquire=yes) new GPS satellites only if the is are one or less listeners online AND good satellites count are less than 4.  If you have for example two listeners online, sate…
