Nik_SV1SYY
- Nik_SV1SYY
- 44
Dear John, I just got a chance to test it. Updated the software, set the delay to 120 seconds and it worked perfectly! Thank you very much once again!
This must be the fastest support I've ever dealt with! Thank you for your work and for this wonderful receiver! VY 73!
It did work. There needs to be a longer delay on power up. The relay only allows for additional 5 seconds delay though, so it's not enough. So if you can increase it in software that would solve the problem. Thank you very much!
Thank you, I'll try that. In fact I had to add a delay relay anyway, so the Kiwi powers up 5 seconds later than the power supply. That's because the linear power supply would gradually increase the voltage upon power up, so the Kiwi with the voltage…
Did that. The Kiwi connected fine. So it must be a router (provider) issue, I guess
Okay, done! It has restarted. Also when I say "hard reboot", I mean the router is also rebooting (as if there was a general power failure).
When trying to connect to http://21018.proxy.kiwisdr.com:8073/ from outside I get: The page you visit not found. Sorry, the page you are looking for is currently unavailable. Please try again later. The server is powered by frp. Faithfully yours, f…
Not yet shipped, the DHL tracking states "Shipment information received WELLINGTON - NEW ZEALAND". Good luck with them gators! Thanks for everything!
Got the message yesterday. It's in the mail, coming to Athens, Greece! 😎 Tnx es 73 de SV1SYY Nik
