Markone
- Markone
- 42
- 1
I gave a try to http://kiwisdr.jks.com:8073/ Kiwi, testing different exponential time constant values, my compromise setting was around 1.0, but with faster refresh rate (than the current maximum one) would a lot higher. I think that the main issue…
I just downloaded the last Rocky release and played a bit with it, it's spectrum graph is way faster then Kiwisdr, by orders of magnitude, as i was remembering. Currently Kiwisdr spectrum takes something like 60 seconds to fall down after a signal …
Hi John, i know very well Rocky from VE3NEA, i used it a lot many years ago with my early Softrock kits and i remember very well that its spectrum decay time is much faster than Kiwisdr spectrum display. As James, i was too wondering if there i…
Usually i play more with threshold slide than gate time, anyhow there are so many variables in play that i think it's hard to establish a common approach to the problem. In my personal case, values beyond 1000us, while cleaning better waterfall, st…
Thanks a lot John, i will put in test the new version later and then i will report my feedback. Just out of curiosity, in your screenshot is visible a "Pref" button aside the "WF rate" slide, not present in my 1.153 version. Is…
I opened the SSH port (22) on the router, you should be able to fully manage the receiver.
Hi John, if you can, give a try to my receiver (see the email that i sent to you for address), it's online with one of the worst noise condition ever seen, NB struggle to work.
In my peculiar situation (receiving site nearby sodium street light) NB function is a must. For what i quickly saw last night, this early implementation is surprisingly effective, beyond my expectations for a first try. @ John : i was expecting a sl…
Hi John, i just sent to you (support@kiwisdr.com) the email with my KiwiSDR web access data.
Hi John, i was going to bed but i saw your forum's post update on my phone, so i promptly updated my KiwiSDR for a fast try ... BINGO ! It's working ! Around 5Mhz, one of the the frequency band most affected by the problem, is obtaining decent r…
"Okay, I am working on adding the simple noise blanker from CuteSDR. I am going to need root ssh access to the Beagle of a Kiwi that has this issue for development and testing. You'd just have to open port 22 on your router and point it at t…
Hi John, thanks for your prompt answer, here belowe my answers to your questions : "How many simultaneous connections were there to the Kiwi when these screenshots were taken? Just one?" - yes, just only one. "Does the red "OV&…
