LIN_in
- LIN_in
- 2,079
- 4
It's tempting, but it's better to be patient and tolerant, as it's easy to make a mistake... Paradoxically, my local blacklist contains over 70 addresses, including several entire blocks. I watch someone like that for even a month, and even if they …
Hi, is it possible to enter your own name/callsign instead of the automatically assigned one? And as a kiwisdr admin, I also notice that the IP location of QiwiQ users is less easily recognized by my device. Overall, it's a great app, and I deserve …
Hello again. I'd find this useful too, perhaps in a new column. But wouldn't that complicate the system too much? For example, I use the alias "mu" in the console, and after a while we have a beautiful file with this (and other) data. I ad…
Yes, that's what I was worried about, who sees it. Thanks again. Lin
OK, you're right! I tested it wrong, sorry, I guess it's just brain fog for a 70-year-old guy. Lin
I assumed it was something more sophisticated... and by the way, once John approves the changes and finds time for your problem, the SNR measurement could be done automatically every time the antenna is changed (but that's a minor thing). LIN
But as a Kiwi owner (with admin rights) you can always force SNR measurement by clicking the button next to the "SNR measurement interval" settings. This doesn't force an immediate change on the main Kiwi search page, but it is visible to …
Hi John, I will also send the admin password to support@kiwisdr.com, in case you need to check something with me. I will change the password at the beginning of May... Question: I did a reset every day: realtime response histograms, clear list user…
Yes, it's just about knowing which antenna is currently in use on the admin page without going to the RF tab (which may not be available). I won't comment on mixing and grounding, because I don't have it implemented in my simple switch. Also, switch…
Yes, there are those who abuse this field for a sort of shorthand communication among themselves. If I could, I would set mine to 8 characters - most callsigns and nicknames would fit. Of course, I would also leave the choice to 64, someone probably…
