KareliaMWDX
- KareliaMWDX
- 0
OK, not a new feature or a bug, either, but what about a possibility to zoom the waterfall still a bit deeper? Maybe only if allowed by the host in the admin settings. The excellent frequency accuracy is kind of wasted now. Thanks again.
OK, thanks, the site name tells a lot already. Seems, that some have blocked low frequencies by filter, but I won't do that for the high ones. And outside winter I'd want to be open all over anyway. BTW, are you still developing the software, adding…
I probably tried to get rid of corrupt html text by setting photo height to 0. Sorry again, I didn't mean to be a bug tester. The second line I don't understand. Yes, I switched External ADC clock to Yes, because in my tired mind when calibrating I …
Please don't blame me: I sent the message yesterday, but when I came here today, the text was in "Post comment" position, although I had definitely sent it yesterday, I don't thin that is my fault?
Thank you for your reply. I have changed it now to ->30000 kHz, let's see, if he accepts my site now. but I'd really want to emphasize, that my site is for MW DX, because 90 % of the sites are good on SW and mine is just fair there and would dedi…
Sorry, John, I didn't notice your comments, I thought I would get an alert to my email, but not. The error I did was found by Colin Newell: when calibrating and being tired I for some reason had concluded, that the GPS receiver that comes with is an…
Maybe that caused the problem. I guess I should delete the admin page and start from the scratch. But where is the admin setup and how can I delete it?
Yes, I tested a text, but took it away, because it didn't work well
Waterfall runs for a while without audio or signals and the it adds "?#" after the URL like this: http://185.89.55.189:8073/?#
Thanks, I'll try, but I can't think of anything more. As said, it appeared unattended and it is the same with other browsers and every computer in subnet and elsewhere.
Right, but what kind of and where? And how did appear by itself during the night?
