KK6PR
KK6PR
129
  • I don't obsessively check, but if I catch anyone tuning in to the 3840 kHz nonsense in the evenings - they immediately get added to my block list.
  • Not sure exactly what it was, Rob debugged it remotely. I've disabled wifi on the Pi and using a cable connection - everything is working fine now.
  • Solved !!! Rob was very helpful getting this resolved. Thanks 73 Rick / KK6PR
  • Powernumpty - thanks I understand what you're saying. Yes, I did the long ping test - certainly longer than the two-minute interval during which this situation occurs. There are a lot of things that are working fine, so many of them can be elimina…
  • Yes, all are on my home network. The IP addresses haven't changed and have always worked. CenturyLink gave me a lot of trouble when I first tried opening the ports for public access to my Kiwis. Trying to set it up via my router's Port Forwarding…
  • Reboots are the first thing I try. When I first encountered this problem I suspected the Kiwis were not getting enough power - they are all running off of two 50lb 12V Marine/RV deep-cycle batteries connected in parallel. One of them was getting r…
  • Thanks - I've been in contact with Rob, he's been very helpful as always. This happens with newly formatted, OS/wsprdaemon installed SanDisk SD cards, with plenty of disk space. Everything works fine until it comes time to report the results and t…
