JohnT
JohnT
512
  • I may have worded my message poorly W1EUJ and I just realized there was also a typo that I have corrected now. I was trying to say that it accepted my entries and that the response to my entries had nothing in it that looked like there was any prob…
  • I have been getting those log entries for the last couple of weeks or so as well I had been into my router to try to block the address but found no way to do it in a Virgin router. Just entered the itables stuff using cut and paste into the KiWi adm…
  • I noticed the same thing with the WSPR decoders failing to auto-start. In fact I seem to recall that WSPR decoders not running first alerted me to a problem. Daniel, yes John can access other people's Kiwis.
  • Hi John First time I have been able to look since my previous post due to some pc issues I had/have. Many thanks for resolving the update problem. Best Regards John
  • Success? Had a problem at first with Martin's cpd command returning a not recognised message but a bit of reading this thread identified it should be cdp.. Once that was resolved all went as per instructions. [I edited his post to now say "cd…
  • Hi Martin Many thanks for the information I will give is a try when I get home. Also thanks to John for the offer to fix it via Teamviewer. If I cannot get it sorted using the instructions from Martin i will be in touch. Regards John - G4HPW / W…
  • My kiwi has crashed while I am away from home and was running WSPR autorun so guess that was the problem. However I have no idea how to implement any of the fixes as I know nothing about Linux or the commands etc. mentioned as I am into radio not s…
  • Good fix on the BBC Radio 4 transmitter near Droitwich, just south of Birmingham. When zoomed in the site was within the centre circle. (Image)
  • Hi Martin It appears that there is a new version of the map plotting software now in use after looking at the link to the maps you posted. Looks like it is much improved over the system that was in use at the time I left which had been in use for m…
  • I used TDOA professionally for a few years as Duty Engineering Officer at the Ofcom Baldock monitoring station before I retired 18 months or so ago. We only used it for VHF and up as it was developed and running ready for the Olympic Games to enabl…
  • Just by chance I have discovered that kiwisdr.local:8073 will work in Firefox provided there is already one tab open! It does not seem to matter what that open tab is looking at, my PC is set up to open on the BBC news page but anything else I trie…
  • Yes I have the problem ever since the Windows April update which arrived a few days ago on my PC. Up to then it was working perfectly. I tried using the ITunes fix which I used when I first got my Kiwi assuming the update had removed it but it has …
  • Hi John A great piece of work from you guys. Many more satellites now being found even though I am still using the supplied aerial by the shack window. I have plans to fit an outdoor antenna over the summer which will make a big difference. The G…
