JP1ODJ
- JP1ODJ
- 74
- 17
@jks I was able to update! http://jp1odj-air.proxy.kiwisdr.com:8073/ Thank you very much!!
@jks Entering ext_send ('SET force_check = 1 force_build = 1') does not update. Is there any other way?
that's right. It is KiwiSDR of jp1odj-air.proxy.kiwisdr.com:8073. I understand. Does not turn the power off/on. It doesn't change. It is v1.462. I will try again.
Thank you for your prompt reply. After entering ext_send('SET force_check=1 force_build=1'), the next screen is displayed. After that, neither KiwiSDR nor Firefox can be seen moving. Should I turn the power off and on after about 60 minutes? http://…
When I display the admin page, only tabs are displayed. http://www.jp1odj.com/window.jpg I cannot enter shell commands. I don't understand the operation. Please help me. (I don't understand English, so I use translation software.)
There is no problem if you have BPF, LNA, Mixer and SG.
There is an affordable SG and Mixer. http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=107&products_id=301 https://www.minicircuits.com/WebStore/dashboard.html?model=ZAD-1%2B There is a similar system in Russia. http://ai…
(Image)
Frequency is 27005kHz
The contents of the log. Sun Jan 19 03:53:35 05:04:57.028 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2 Sun Jan 19 03:53:35 05:04:57.028 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2 Sun Jan 19 03:53:35 05:04:57.028 01.. IP BLACKLI…
Postscript. Change the IP address to access.
The basis is as follows. Always the same frequency, mode, long access. Access many times even if kicked. It tries to connect many times even if it is kicked automatically. (After blacklisting)
New IP address blacklist 205.185.127.219/24
That's right. Wide FM gives up.
