IZ0INA
V1.699 blocked – (debian V8.5) I start looking for the problem by running "check for software update" as a response it tells me that The installed version v1.699 and GIT clone damaged! At this point I turn to the FORUM, it shows me several really difficult solutions, I choose an easy one I think can solve the problem. To explain myself well I attach a short text: Obtain a micro-SD card at least 8 GB in size. Mac & Windows: Debian 11 -- BBG/BBB version Download this 769 MB .img.xz file to your Mac/PC (SHA256: 5502e8f5f43deac988d4193a8945c00128095d515d1b2ac15c4406dac189dcb0) KiwiSDR_v1.690_BBG_BBB_Debian_11.9.img.xz Once I inserted the micro SD into the BBG it never stopped shooting for more than two hours. How can I solve the problem? My PC uses windows 10 + Google Chrome Thank you very much
IZ0INA
57
  • I start by disconnecting the first Kiwisdr 8073 from the modem, then install the second one with port 8074, and finally reconnect the first one. On the map, I see both Kiwisdr overlapping each other, but they respond well to commands. Thank you so m…
  • I'll do some dusting and keep you posted. Thank you very much.
  • ho eguito questa procedura del kiwisdr_v1.690, ma con risultato negativo. Inserendo la micro sd nello slot del BBG una volta avviato continua per ore senza fermarsi. Penso che sia meglio che tu dia uno sgurdo al mio kiwi. ti invierò le mie credenzia…
    in V 1,699 Comment by IZ0INA October 2024
  • https://forum.kiwisdr.com/index.php?p=/discussion/3384/v-1-699
    in V 1,699 Comment by IZ0INA September 2024
