Highspirit
Highspirit
16
  • I might have an idea about the Kiwisdr 2 that you might increase the frequency range so that you can also hear the other bands such as from 30mhz to 1.3ghz 73 Highspirit
  • kiwisdr is running again and could after I created a better power supply of 5V, it was easy to install and also with a larger micro SD card (32GB). This was possible without any problems Thanks again for your help.
  • https://forum.kiwisdr.com/index.php?p=/discussion/comment/16468#Comment_16468 Which build is best for the beaglebone green? You can give a tip there and, if necessary, provide a finished script
  • You're not able to follow the instructions here for downloading the Kiwi Debian 10 image to be placed on an sd card yes i did it but no reaction on the beaglebone what could it be What is the issue exactly? You don't have a way to write sd cards or …
  • I wrote it on the sd card, but my new beaglebone green doesn't react to the image, so I'm starting to despair of it Is there somewhere a finished image for the beaglebone green as with the original SD card
