Henrikc
- Henrikc
- 179
- 1
Hi Martin, ok, thanks…he does not give away much on the home page….. 73 Henrik
Thank you JKS right, I am indeed using the local for that, but my TDoa incident involved different russian IPs all starting with 213.87., so I thought they qualified, as I also trust they did not only use my Kiwisdr for their excercise, but your cho…
Thank you JKS, Do you add an appropriate IP-range to the downlodable blacklist please, to cut out these guys….then I can turn on GPS for legit users….and keep an eye out for reapperance? Or how do we suggest/report additions to the downloadable comm…
Oh, be warned, shipping is an other 11.21 On top! 73 Henrik
Martin How did you manage with only 16 characters available? BR Henrik
Thank You! A nuisance less for me with this fix! Works fine with my Ipad/Ios 17.5.1 BR Henrik
@ JKS How I returned to v 1.690? As I recall, I went to the Admin interface, update tab, and checked for updates….and again as I recall, 1.692 and 1.690 were avaílable, so I checked 1.690 and forced a build of that. Today I do not see the posibili…
Right, thanks.... My later afterthought was that it perhaps was related to the new release...now: take your time and rest.....you must have had a long night! All working fine for me now with 1.693, but funnily not by reverting manually from 1.691 to…
Hi John,thanks Trust you have much more on your plate right now....and actually, the /?m does it for you!! Perhaps a more prominent presentation of this possibility would have solved my misery earlier..... BR Henrik
JOHN, Thank you!!! Great job renewing the firmware again and again with user input and requests, but so much more respect for your quick response when things did not go quite as planned today! Returning back to 1.690 did not go all well for me, but …
With v 1.693, IP reports are back to normal.... BR Henrik PS: how do I close a thread?
Certainly When any button is pressed in the userpanel, the keyboard pops up, and the frequency input window is highlighted for input: https://forum.kiwisdr.com/uploads/691/3J56JBD5AY1X.png So if you adjust the zoom, volume or mode, you have to get r…
Thank you John for the explanations! BR Henrik
@jks thank you for taking time to comment and enlighten me….. I do not think you skould do anything about this….if I get annoyed, I can ban the IP…..and see if it helps. Wonder if users from Russia could be related to support of state activity not…
DL7AWL, brilliant idea to test with VPN! thanks for info!! BR Henrik
DSC seems interesting, and I support the idea to have distress messages decoded to, please. 73 Henrik, OZ6F
