Found the problem, the modification in the web-backend is not sufficient, I had to create the ETC-config-file too, now it works fine...According to the instructions you could do one modification or the other, but both are needed... 73 de Mark, HB9AZT
Hi Kari Thank you for your great antenna-switch-extension for the kiwi-sdr! I installed a MS-S7-WEB in my lan and can reach it via browser and do all the switching. I changed the ip of the switch to 192.168.1.24 and adapted the config-file of …
