Hello JKS, I attempted to set aside the current build files with this result: CONSOLE: open connection bash: cd: /root/Beagle_SDR_GPS: No such file or directory root@kiwisdr:~# df . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk0p1 3.5G 1.…
Hello circuitmike. I'm also on a tiny city lot - 33x100' in the middle of dense Vancouver. I also have huge noise problems (which is why set up a remote rig on an island). My beam antenna is only 35' from the ground, on a 2" aluminum mast from …
Thank you for the detailed responses. G8JNJ does seem to confirm a 1.5 s latency but I don't understand: "response of the KiWi controls is still fairly instantaneous." My experience is that all Kiwi controls have 1.5 s latency including fr…
Although I’m a new KiwiSDR user, I have tested several SDRs and operate an IC-7300, which is an FPGA SDR radio. I am an electronics engineer with over 50 years experience with communications receivers. I don’t deserve or appreciate condescension fro…
