Hi Thanks for the reply The antenna switch has never been used and none of the option in th Extensions page have been changed. The webpage gui also shows it's disabled. I'm still running V1.698 FYI I've had a fiddle with the switch settings even th…
Hi Martin the run of coax is quite long at about 70mtrs and even though it is FSJ-450 hardline the loss combined with power injectors etc is 2dB or so at 30MHz. The gain of the amp also drops from 11dB to 9dB at 30MHz. I have a provision to split …
I've just installed a Kiwi 2 and was concerned about how much power it maybe exposed to from my main transmitting antenna which is parallel to the Kiwi loop and only about 100ft away. So ran the tx up to 200 watts output on each band in turn from 1.…
