G4KGA
G4KGA
156
  • Pretty sure it's not mine. I can pull the cable out of the wall and the "modem" and nothing changes on the spectrum. I'll try a maintenance call to BT ... but not holding out any hope.
  • Thank you. Oh dear - yes - http://rsgb.org/main/files/2020/03/How-to-identify-VDSL-interference-v2.pdf ... I have noise from 2.250 - 3.700 MHz (very distinct boundaries), then clear, noise 5.250 - 8.450 MHz, then clear, noise 8.555-11.950, then clea…
  • Well - I'm kind of disappointed. Getting the TP-Link made no difference. Same noise bands ... TP-Link 0-30 MHz at the top, cat6 0-30 MHz below. And changing the Kiwi to use 100 Mbit to the TP-Link introduced the same spurs as it showed when on the c…
  • Seems to be more the time it takes for a smoothed supply to get to 5 volts from switch on.
  • Just received a linear power supply from https://www.ebay.com/itm/113160740684 Works well The one thing to watch for is that plugging everything up, then switching on the power supply ... the Kiwi doesn't boot up. You need to switch the PSU on first…
