                Thanks, John, it's working perfectly.
                Wow! I just tried the extension via the KERNOW KiwiSDR - it worked perfectly. This is awesome stuff, what a great job, John! Thank you so much for your attention to this.
                I assume I have to wait for the Kiwi providers to update their software, as I'm merely accessing their page on the web.
                Tremendous, John, thank you. As and when...
                That's exciting, John. I am very happy to test with you as and when. Let me know how I can help. Feel free to email me directly if that is easier. It's such a useful extension, hopefully your plan will come to fruition.
                Hi James, interesting thought. A 'keep alive' routine of some sort, ideally not with me having to do it manually, though! Strange that the connection should closer so quickly.
                Crumbs, that sounds a bit naughty on the mobile provider front. Thank you for looking into this. At least we now have a solid reason for the issue. I guess some other users must be experiencing the same and at least I'm relieved that it is not so…
                Awesome, thank you. I can keep triggering if you wish. Anyway, next one coming up 2015
                Coming right up!
                OK, at 2005 UTC
                Excellent! Thank you for your time. Do you want to go to a different messenger to save filling this up? I can do Echolink for example. I think the IP address you're seeing there for me is not one I can see on my router here!
                OK, trying at 1945 UTC
                It's all a bit wild on the IP front because it's possible to bounce cells pretty regularly. It's currently ends in 178.105 I think!
                Sorry about the IP address change - I guess the cell dynamically allocates. Will repeat test at 1930 UTC.
                Just to report back that the process stalled as usual after the 30 sampling period during the 1742UTC test. I changed the 4G LTE router to MTU 1440 and retried the test, but same result. I'm still wondering if it is a security issue. Is it possible…
                Thank you guys, I really appreciate the time you're taking to help! I think my IP should remain static for these tests. OK, I am giving it a try now via the Kelvedon Hatch GB0SNB Kiwi at 1742 UTC. Frequency will be entered as 12.345 MHz. Steve G4HPE
                Thank you both, Martin and John. Martin, I tried your suggestion but again the process didn't complete. Most strange. Thank you for taking the time to reply. John, many thanks for your help and advice. I've tried three or four different KIWIs but…
