F5MMX
F5MMX
39
  • Here are some further tests I made. Current consumption, is 140mA during the time the PWR LED is activated then it drops to less than 1mA I disconnected the Beagle from the Kiwi2 board and used jumpers to hook the 2 units, when only GND, VDD 3V3 and…
  • Each time I connected the cable with power ON onto Kiwis plug and it didn't change anything in the behavior of the Beaglebone, power LED turn On for a fraction of second and turns OFF again. I'm feeding the Kiwi2 with a 25cm long 1mm² cable, so the …
  • So I tried adding a large capacitor on the connector side with no effect. I changed the PSU to a 5V 10A and no difference. Would any have an idea on what to check next? Many thanks
  • Thank you for the input, I'll add a large capacitor on the cable at the connector side to see how this behaves. The setup was running fine during months, but maybe the PSU is now showing an issue.
  • Retrieved mine on Thursday, what an amazing piece of art. Thanks a lot. Kind 73, Jean-Michel - F5MMX
