F5AFY
F5AFY
2,093
3
  • Hi all, It seems that you can manually launch the scanning in the "local" menu, click on the "scan" line of the url list of interest. ( If you click the "stop" button then you can click "scan" as usual to rest…
  • ... and you can try a "KiwiSDR server restart" on the Admin/Control tab, do again the "Check port open", and see if your Kiwi appears on the list...
  • Hi Chris, @VK6KCH, Your Kiwi seems not to be reachable. A router configuration problem probably. Could you, please, go to Admin/Network tab and click on "Check port open button" and see the answer ? Do you use the "Auto add NAT rule..…
  • Hi Francis, F5LFE, Here it is said 8GB or larger : http://www.kiwisdr.com/info/#id-install Just insert it in the Beagle Bone socket, and "Click to write backup SD card" in the Backup tab. You will see live informations about the writing pr…
  • FYI @jks, after upgrading smoothly -> v1.807 -> v1.808 (I was already D11.11), I did the usual backup SD card without problems, I got to the Log tab, and saw the following ("SYS_PANIC"). Everything is working fine, though. Thierry ..…
    in v1.807,808 Comment by F5AFY April 10
  • Hi Fabrys, You may be in the case where you need to locate the boot button on the Beagle Bone, hold it and then finally apply power to the Kiwi so that the flashing process begins, as described here : KiwiSDR Operating Information I hope this may he…
  • Hi, @ShaneBrook , All, Please try : grep -ai leaving ... ( I think grep finds binary ans it doesn't like... )
  • @dl7awl No worry ! 😉 @jks Thanks. I'm not in a hurry... France is quite a dark area on the map. It would be worth to have good sites like the one of Philippe @Tremolat or the new F4KIY (http://83.112.24.168:8073/) 73, Thierry
  • Hi Manfred, Thanks for the answer. But, of course I meant : Will 'sold out' disappear ? Or ML&S, Wimo or another one, will add this possibility ? 73, T
  • Hi John, and all, Will it be possible to order the cape only ? I guess it's a bit less work for you to send the tested board only... Congrats for the huuuuge job done !👍️ Thierry
  • Hi all, I also like this color scale. May be, these profiles are a useful base ? (The red end is a saturation indicator) [ For my first post, congratulations and thanks to the -whole- "Kiwi" community, and first of all to John ! ] 73, Thie…
