                After installing the emergency image, the GPS is running again. No idea what exactly the problem was... http://forum.kiwisdr.com/uploads/221/Q8VVAGFXULJO.png
                The problem has been going on for 2 weeks or so, I can't say for sure. I only know at the beginning when I put the Kiwi into operation, the GPS ran as I expected. At some point I noticed that he no longer gets a fix and then I tried some things and …
                I already tried an another GPS Antenna, same behave.
                The 3.3V of the SMA socket of the GPS antenna are present. I have already tried several restarts of the entire KIWI. Last idea would be to restore the emergency image from the SD card and hope that this solves the problem.
                I can also put the antenna under the open sky, that won't change much. It has also worked properly before, the whole list was full with the receivable satellites. And there was a GPS fix without problems.
                I am "Dumb" ;-) The "80m JP" Option do that i expect. But why "80m JP"? 73 DO1DSH
