CommSigma
Located near the CT/MA border I run the following online receivers.
My 0-32 MHz Kiwis (x4): http://sigmasdr.ddns.net:8073
My 0-62 MHz Kiwi clone: http://sigmasdr.ddns.net:8077
- CommSigma
- 109
- 2
I'm in for at least two
I do have a multicoupler on my four current KiwiSDR v1 receivers. I do have two more ports on it so I am able to do the A/B test. I run a 80-6m OCF dipole at 65 ft and have a decent location to be able to produce some meaningful results. Please let …
Nothing fancy, just a shelf in my workshop/radio room. https://forum.kiwisdr.com/uploads/901/4CTBFBTUJMN4.jpg All four KiwiSDRs go into a Mini-Circuits 6 port multicoupler attached to an 80-10m OCF dipole at 65 ft. Signal levels are high enough he…
As a former manufacturing engineer, I would agree with through-hole SMA connectors (or anything else that connects to external cabling) for strength if you can do it and costs work for you. One less point of failure and we all know how much a piece …
Yea, agreed, great fix. FM demod is MUCH better. Thank you! Rob
If an admin MOTD-style message field was implemented it would be great to have an auto antenna detect message or just automatically change the background color of the MOTD when it was disconnected. Just some thoughts that I'd like to see make it int…
I use Chatango for admin messages. There are a few users who converse on it but mostly I use it for notices that I've disconnected the antenna due to a lightning storm. Works pretty well for me.
Yes, thank you! Been looking forward to that feature. Rob
https://forum.kiwisdr.com/uploads/672/2T6CKOYENANH.png I have Chatango running on my receivers. Code gets added to the Additional HTML/Javascript for HTML section. Allows users across all my Kiwis to chat and allows me to send administration message…
I'm hoping the DX tab in the web admin will eventually aid in doing some of this. I also would like request ability to upload DX labels via a text file and then allow quick editing on the DX tab if necessary. Maybe adding a category field or tag to …
My Kiwis also have the script installed, too. Made a big difference to my Android users. http://sigmasdr.ddns.net:8073
Yes, the /8 block on 34 and 35 addresses seems prudent right now if you want to eliminate IP changed connections. We need to keep an eye out to see if connections from outside those ranges become a problem. Hopefully, we'll have some information soo…
I was seeing SYN flood warnings on my router from those addresses earlier. Seems to have slowed down now and no new warnings for several hours.
Too early to tell if effective yet, but I have implemented the block on my four Kiwis. I'm looking at it being a brute force obstacle until the issue gets identified/resolved.
I have one of my four Kiwis stuck on v1.470. I did the manual update via the Update tab in the web interface, no go, I SSH'd in and did the update_fix, no go. Anything else I can try? Thanks.
I would appreciate this feature as well. It would be nice to be able to import and view the labels in Excel and be able to massage them to suit my needs.
New version out with new features - graphs and alarms. http://forum.kiwisdr.com/uploads/752/CHII4MT8R8N4.png http://forum.kiwisdr.com/uploads/529/26YXU0N6ES6C.png http://forum.kiwisdr.com/uploads/492/CEIKYXOY74LH.png http://forum.kiwisdr.com/upl…
The squelch is much appreciated here as well. Bonus on the selectable squelch tail, too! :)
I do the same on my Kiwis as well: http://sigmasdr.ddns.net:8073/ - Rob
I can see this as a valuable feature, too. It would definitely add value to all the SWBC listeners on my receivers. Could have utility beyond SWBC as well.
Thank you for checking. I also did some testing prior to posting but wanted to make sure I wasn't missing something or a way to force this behavior. I could see how this might be a useful check while in the 8 channel mode because I would tend to thi…
I'd like to echo Chris' request in that it would be helpful to be able to have local chat capability on the KiwiSDR page. As an admin, it would be nice to send a message (either directly or via a chat) to one of the users as well as a system status…
