ChrisSmolinski
- ChrisSmolinski
- 3,886
- 6
Very handy, thanks for the tip!
Martin, Right, the app is purely meant as a logging tool, there's a subset of DXers that run decoding sessions every night to see which stations can be received. It's not used at all for GPS correction, although as you note it certainly could be. …
jks, Projects always seem to evolve in different directions vs the original plan, don't they :) What initially attracted me to the KiwiSDR was the ease of putting it online for others to use, since I live in a relatively low noise environment an…
Ron, The Mac version of the app can decode from RFSpace and AFEDRI SDRs by directing interfacing with them, which I do from time to time, although I mostly just record a 50 kHz or so spectrum overnight and then run the IQ files in the morning. It i…
I used ethtool to drop to 10 Mbps, no change noted here, but I am not sure if the problem existed anyway? I use shielded ethernet cables in the shack, and my coax cable runs to the antennas go down the side of the house, then underground 60 to 100 …
Is there any way to get a 40+ kHz wide IQ signal out of a KiwiSDR? I could possibly modify my Amalgamated DGPS program to decode in real time if there is. It's likely way too processor intensive to do it on the KiwiSDR itself, to even consider por…
Perfect, thanks!
I just noticed this happening as well, using Safari on the Mac as the browser. I hear it listening to my own KiwiSDR using the local network address.
Yep, I have been spreading the word on several groups I am on, as well as the HFUnderground.com I know I got several people to buy one :) I write SDR related software, I could see some potential uses for a second dedicated unit just for experime…
Just put mine together, the instructions were excellent.
My KiwiSDR via MassDrop just arrived (I am in Maryland). Getting it set up now.
Yes, mine is supposed to arrive Friday, it just got to my local post office tonight. I guess I need to sort out the PSU after all :smile:
I punched the tracking number I got into the FedEx site and it shows a location of Edison NJ, so they are in the USA. I am not sure if they are shipping express or ground, my guess from previous drop comments is ground. I'm in MD, so at least it is …
I built a four crossed parallel loop with the LZ1AQ amp some time back. It works remarkably well for the size, and is fairly directional on LW and MW. I have a bit of an antenna farm here, 670 ft sky loop, several dipoles and three short (300 to 50…
