ChrisSmolinski
- ChrisSmolinski
- 3,976
- 6
I was thinking about this, and it gave me an idea. Sorry, the idea means a KiwiSDR feature request :) As it is now (I think) any KiwiSDR receivers that are password protected are not available for public use. This means in many cases they potenti…
Squelch is a great addition, thanks for adding it! Testing it now on the CB band.
Thank you! Perfect.
The iframe extension is very handy, I use it to embed the HFUnderground.com chat. Is there a setting to change the name of the extension from iframe to something else? I figure if I could change it to Chat, it might get more users. (This could apply…
At least I know now that I can shelve any plans to further raise the height of the outside GPS antenna to improve coverage to the north. Speaking of GPS... I have the one outside high gain antenna feeding my Thunderbolt 10 MHz reference as well as…
Thanks for adding the ability to set the default color map. btw - I also really like the SdrDx mapping. Perhaps because I am a long time SdrDx user :)
Thanks for mentioning the "polar hole", John. I mistakenly thought it was due to the line of evergreen trees directly to the north of my outside GPS antenna :) (Image)
I routinely check http://rx2.wa2zkd.net:8073/ in the late afternoons to see what propagation from Europe will be like later on here, for pirates in the 5-7 MHz range. Your KiwiSDR is about an hour or so ahead of mine here in Maryland for those signa…
Perfect, thank you!
Is it possible to set whether auto or manual mode is enabled as a default for visitors to the KiwiSDR? Auto mode (at least on my KiwiSDR) seems to produce a too difficult to interpret waterfall, at least with the default gain settings.
Hi John, Yes, the second solution is what I was thinking of long term, directly modifying dx.json was a first step of "can I get something to work, having never touched this code before".
While I have a few decades of experience programming, I've never done anything with the KiwiSDR code other than look at it :) I'm more than willing to give this a try myself, if someone can point me to even some brief instructions for how to do a…
Checking my overnight netSDR recordings on 43 meters, I see this signal was present, quite strong, starting around 0000z or a bit earlier. So it's likely strong on my KiwiSDRs as well, if anyone wants to use them for TDoA purposes. I have a fairly l…
We've been discussing this over on the HFUnderground.com for a few years now, as some of their transmissions have impacted our listening pursuits due to interference, for example: https://www.hfunderground.com/board/index.php/topic,42596.0.html I t…
The audio sounded OK on some 25m SWBC stations I listened to. The change you see in the waterfall is probably due to the changes in the waterfall: http://forum.kiwisdr.com/discussion/2112/v1-403-colormap-improvements-multiple-drm-schedule-databases…
Thanks for the colormap enhancements, John, greatly appreciated! Speaking of user settings, is there a way to save the bandwidth settings for the various modes (AM, etc)? For example, I prefer to keep the AM bandwidth down around +/- 2.8 kHz or …
A few suggestions, you may have already tried some of them, but here goes... (I assume you have one of those integrated routers/modems) Disconnect the coax cable and ethernet cables from the cable company router/modem, unplug the power supply from…
Mouser now shows 28 KiwiSDR Expected 10/2/2020 They also show 12 enclosures in stock, 14 Expected 11/23/2020
The KiwiSDR is back in stock at SEEED https://www.seeedstudio.com/KiwiSDR-Kit-p-2725.html
I have very occasionally heard one or two US LORAN stations on the air for what I assume are tests. I have not seen announcements of these, just luck that I checked 100 kHz and found them on the air.
It would be amusing if the KiwiSDR allowed us to feed an audio stream into it, and specify a frequency, and have the audio appear there to any listeners. Think of the possibilities :D
What I'd find interesting would be the ability to not use passwords to "reserve" receivers, but instead let someone use a password to "bump off" an existing (not local) connection. That way the receivers aren't put out of commiss…
I went down the higher performance outside GPS antenna route a year ago (see my post(s) above). I added a second KiwiSDR and split the signal to it as well, and both are getting great signals and usually tracking 11 or 12 satellites (I have a shadow…
Perfect, thank you!
Is it possible to get the URL to set the mode to DRM? It seems to work for other modes, but when drm is in the URL the Kiwi opens in AM mode. Or am I doing something wrong? (Entirely Possible)
A year or so ago, I went down the rabbit hole of trying to come up with an automated measurement of the SNR/"quality" of online KiwiSDRs. It's one of those cases where you can look at a waterfall and pretty quickly decide how "good&qu…
Thank you for catching that! Seems to be correct now.
Well, this is curious. The temperature is the same. Within one or two tenth of a degree F anyway. I can cool it about 5F further by blowing air into the chassis vs drawing it out (which seems reasonable). I am not sure if that increases the chance…
Mine arrived late this morning, speedy DHL delivery for sure. I just put it online after completing lawn mowing chores. I had to re-remember a few things regarding setting it up :) Cloning worked great to move the DX Labels and such over. Not a …
Thanks for the suggestions! Here is Version 2.0, I mounted the fan on a piece of plastic (from a kids lunchbox that was going into the recycling bin) to direct more airflow through the power supply chassis. (Image) The cutout is not terribly nea…
