ArturPL
- ArturPL
- 3,011
- 4
This is what I was looking for, and can you provide a value code for the AGC Threshold, Audio Volume and de-emph and WF rate settings?
Ok it worked I did as rz3dvp wrote, copied via WinSCP dx.json from the kiwi.config folder and restarted the devices Thank you for your help
Something is wrong with the network, because only from the 192.168.1.123 device I can not clone to the second SDR with the .124 ending, but the same .124 from the third receiver with IP 192.168.1.125 can clone without any problems, even though all t…
[Only after entering the local IP 192.168.1.123 this procedure works.] Unfortunately, the tab clone option does not work again. I wanted to update the new DX labels and I cannot do it over LAN Status:host unknown/unresponsive
I confirm the same v1.487, disabled ALE_2G and HFDL extensions still available to users
As a reminder, the exact data about the signal sender can be obtained by hovering the cursor over the frequency bar in Kiwi, right-clicking and selecting SWBC database lookup.
In the summer, an hour before and sometimes up to 2 hours after sunset, AM radio stations (their sick powers are often 500kW), which I normally receive 20-40dBm, sometimes shoot 50-60 + dBm for 5-20 seconds, the Kiwi indicator stops showing OV only,…
Too large input signal, I have the same thing when I turn the gain on the board to the maximum value in the MLA-30, then the stations in the 49m and 41m band do exactly the same mess. Lower the antenna gain or use an attenuator or band stop for AM s…
In today's VPN world, this function with providing user data online is completely redundant. This panel could be a place for other functions, e.g. for people using mobile devices, a nice thing would be larger programmable buttons from either the adm…
I keep banging on three receivers, until port 8073 is blocked on proxy.kiwisdr.com and falling out of the network, reported and nothing Sat Dec 25 13:24:19 14:20:18.770 .... CONN: 127.0.0.1 X-Forwarded-For 34.70.254.107 Sat Dec 25 13:24:19 1…
for now, the current host name is after the last attack, so Winnie the Pooh came instead and maybe censorship will disable access by itself, let's check 😀
Yesterday, 2 out of 3 of my Kiwis that I share with the proxy flew out of the network and the logs showed exactly the same activity with 34.0.xx 35.0.xx Although the domain registration was ok, when checking the port opening I got the message- .prox…
I recently bought a cheap power supply for a PC, now I have a very similar muck on the waterfall when I turn it on from 0 to 900kHz, before connecting an additional strip with a filter + a few ferrite clamps, it was more up to 1700kHz. The same mess…
After downloading 1.463, the receiver broke down completely. I can log in to the admin panel, but all tabs are completely empty. The Kiwi page fires up but only a photo is displayed, the drop down bar has expanded to halfway, no waterfall, no clock.…
Hi SNR reports are often exaggerated, and in my location where background noise is very annoying, I used multiple antennas. The best result was on a Delta antenna suspended at 10m, where after using bandpass filters and a 3-10MHz preamplifier, cutti…
I did a 12 hour test with 20MHz spectrum masking and actually the linkfanel map doesn't update that. It still says Blocked spectrum: 10.7% and the only change is next to the timeout icon ⏳, adding the icon 🚫. The case is cleared.
Hello I managed to clone the lan so I don't complain. In the future, you will have to connect a new device next to it and import the bookmarks, and then install it elsewhere and apply any changes manually. Most importantly, I have to go out to the w…
And for the more lazy you can create a DX label on the band you are interested in. You set the frequency, the type of modulation and in the Passband window for the LSB you set -3000, 0 and for USB 0, 3000 you add to active and you have a 3kHz ready …
From my own experience I know that two antennas, and in my case three :) can be adapted to improve the signals. I don't know what antennas you want to use, but at home I adjusted the mini whip, delta and vertical stick so that the signals from one d…
In my case, out of 3 KiwiSDRs I purchased, two of them had a problem with the original card. An oxidized layer of white coating has formed on the contacts, which must be removed mechanically using, for example, a 0.5mm precision screwdriver. A few s…
A properly grounded mini whip also works, mine hangs on a fiberglass telescope 15m from the ground and over 5 from the roof. http://forum.kiwisdr.com/uploads/333/H6E1KV70I5HV.jpg
I had a similar case in August. On both receivers I only received one gps signal, which was very weak. Everything returned to normal by itself after 3-4 hours. Antennas glued to a metal roof 10m above the ground. In my opinion, it was either due to …
Is it possible to add in the Config tab the settings for WF ceil / floor in Aperture Auto mode to start with 0dB values? The waterfall then looks much better than the default ceil + 5dB / floor -10dB greetings Artur
Additionally, shielded RJ45 cable with CAT.6 standard or better, with which you connect Kiwi and router + its grounding, and no more Ethetnet noise. But remember that if you also ground the power supply from the same point, the effect will be opposi…
Thanks for the quick fix, it works fine.
Great job with that lockout. I know there was already a thread asking for the ability to block IQ or Comp, but another nice option would be to have as default the Audio filters with std-wdsp-75us settings set by the administrator just like the defau…
I use efficient thermopad on all heating elements instead of the fan and everything works stably
Phil If you haven't managed to make a backup of sdr.hu, as probably most people, then use https://web.archive.org/ mark the date before closing the project and it's ready, I checked it works. There is also the https://www.receiverbook.de/ project w…
Hello I will add that the same effect causes NO error in html, only incorrect entry by the administrator in the Config tab, if in the "Waterfall min (dBFS, fully zoomed-out)" window you enter the same or higher value as in the "Waterf…
Good morning I am getting another new signal from China best regards Artur (Image)
