ArturPL
- ArturPL
- 3,047
- 4
It worked for me, after a week of masking, they gave up listening where they are unable to pick up, patience.
You can also mask the 4.5MHz bandwidth they love or any other where they stand by adding it in the DX tab https://forum.kiwisdr.com/uploads/381/I03FT0ST90BN.jpg https://forum.kiwisdr.com/uploads/805/YETIAW1F77O9.jpg https://forum.kiwisdr.com/uploads…
Managed to. I created an SD card from flash and the Kiwi came alive. I also found the culprit - the power supply I am surprised, however, that the other two of my Kiwis started from it without any problems. Currently, I used an emergency ZHAOXIN RXN…
Ok, I'll write what came out of this later
I already tried to restore from SD but it loops and again cannot start from the local address via http (ssh works), probably the backup was already overwritten with an error in 1.566 I can try from a working 1.567 kiwi card or from the original one …
https://forum.kiwisdr.com/index.php?p=/discussion/comment/15014#Comment_15014 I wanted to repair my receiver but I get this: Debian GNU/Linux 8 BeagleBoard.org Debian Image 2016-05-13 Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debi…
One of my three kiwi crashes with the 1.566 update For about 2 hours he did not respond to his address 192.168.1.123:8073, now he has surprised and has it like this: Installed version: v1.566, built Oct 17 2022 19:13:12 Git clone damaged! connecte…
Hi Kiwisdr in PL, apart from ErcomER, is also available at Konektor5000 (reliable equipment supplier), you can buy directly through their website and a little more expensive through the Allego auction service (currently 2 pieces)
Fri Sep 2 17:23:03 1d:21:23:37.261 0123 3 L 58.59 kHz WF z8 "Pony_Cook" 149.248.51.191 (ARRIVED) Fri Sep 2 17:23:12 1d:21:23:46.804 0123 3 API: decided connection is non-Kiwi app (0) Fri Sep 2 17:23:12 1d:21:23:46.804 0123 …
You're doing so many surprising things here so it's obvious the wait has to be, thanks 👍️
I missed it, thanks!
Where can I find a list of all the commands that can be run after :8073/?
Unfortunately, there is no option (yet?) To disable IQ like DRM, but there is a way to prevent this annoying botnet from working properly, in the admin panel in the config section, select IQ and passband mode for HI and LO, set by default not 3000Hz…
Hi I have two ideas 1 (useful in mobile mode). I would like to propose to change the name of the OFF button to View, because this way of changing the display to press it repeatedly, is known only by a small number of users of mobile devices and from…
And here comes a question that may have already been asked ... Could it be possible for WSPR to start automatically when there is no active user on the slot and to shut down when someone tries to connect?
I confirm, now when I turn off the desktop mode in Tizen the icons of the link frequency and the width of the 9 / 10kHz channel disappear Thanks again for your effort
Everything is as it should be, I read the topic with changes in the new version and after adding :8073/?m Kiwi starts in the mobile view. The factory Samsung browser (TizenBrowser v3.1.11260) has a mobile view in the options, but it did not respond …
https://forum.kiwisdr.com/uploads/909/UBVOFVVZANMK.jpg so fast, it doesn't matter if I turn on desktop mode or not, the panel stays in desktop mode
I just came back from a long weekend and I'm not up to date, I have to update devices from 514.
In the smart tv with the TIZEN system (Samsung), which works with Kiwi really steadily on the factory browser, each selection of any ZOOM control icon, +/- frequency, shifts or selection of the DX label results in calling up the keyboard on the scre…
v1.506 the problem is gone, thank you
The Website tab gives us a lot of options when it comes to individual needs, and that's a good thing. You just have to be careful about the correctness of the HTML code, I forgot about the parentheses once and Kiwi did not want to take off. Coming b…
An interesting topic, so maybe I'll start. Time widget at the top of the page (used to be a separate topic in the forum) useful and free. You open the website of the time service provider https://time.is/widgets You choose what is to be displayed ac…
I set the value to none, after 3 seconds from showing the waterfall on the browser I get this: https://forum.kiwisdr.com/uploads/312/4VYHPRQF1DLJ.jpg so there must be one allowed, then it's ok
Some solution? previously it was 11m in navy color https://forum.kiwisdr.com/uploads/408/78V6OCKOIT9A.jpg
I checked on several receivers and the changes in turning the compressor on or off are negligible, almost zero, and the effect is completely different than with the Threshold slider
Thank you for a great job
114.249.0.0/18 Chinese bot, when connected without identification and showing no typical user characteristics, just takes up slots
it would be nice to block by name, e.g. * .adsl.xyz.xy and a separate tab for your own list that does not disappear after retrieving a new list like it is now
Excellent Thanks a lot I used to rummage at Openwebrx, but forgot about it;)
