ArturPL
- ArturPL
- 3,046
- 4
For a long time, I masked all traffic outside the amateur/utility/AM bands, and for about three years, I was able to identify networks whose channels were still occupied despite being blocked. The pool is twice as large as the official blacklist, mo…
You can define the channel values for each band, whether amateur or broadcast, in the DX/Band bars tab in the Chan section, enter 1. Next to the band you want to edit, the + and - buttons will change the freq. every 1 kHz, so for AM stations it wi…
Hi, in my user list, apart from the normal connections, I also see this: 127.0.0.1 West Virginia, USA 0:00:00 "i like cheeseburgers" 127.0.0.1 West Virginia, USA 0:01:16
Hello, today another one Mon Mar 3 21:57:13 4d:00:07:21.649 01.. 1 foff: foff_set_in_URL=0 foff_in_URL=0.00 freq.offset_kHz=0.00 Mon Mar 3 21:57:14 4d:00:07:22.567 01.. 1 L CMD_MARKER: unknown variant [SET MARKER min=0.000 max=1875.000 zoo…
After several failed attempts as described and today's planned restart, the serial number returned spontaneously in the NETWORK tab, the model field remained empty but in the STATUS tab there was still Kiwisdr 2, I went to Console and cdk again and …
Yes, I mean that I currently don't have root access because Debian 11 has limitations after entering the commend I get this root@kiwisdr:~/KiwiSDR# m dump_eeprom KiwiSDR cape EEPROM: hexdump -C /sys/bus/i2c/devices/2-0054/eeprom hexdump: /sys/bus/i2…
Hi I just noticed that my Kiwi 1.800 also shows up as model 2 and its serial number has been deleted exactly like in this thread. A week ago we had a transformer trip here, they turned the power on and off several times but the intervals were long a…
https://forum.kiwisdr.com/uploads/644/2LLUK47OKVA6.jpg Something new, it set itself to a freq. that my SDR does not support after a kick it returns and still no reaction. for now I block the entire IP pool 92.72.0.0/13 there is another botnet with v…
removed from that thread, I'm pasting it here If I remember correctly, on Saturday your Kiwi was online for several dozen minutes and worked normally, but not through the proxy service but from the public IP of the Vectra cable TV, which DOES NOT h…
It is 99% electronic waste called on internet auctions as INTELLIGENT MICROPROCESSOR CHARGER, I had the misfortune to buy it once but I returned it the next day after purchase when I saw my waterfall, while this yellow garbage was working, it looked…
it's been going on for over an hour Mon Nov 18 19:40:13 5d:00:26:32.827 01.3 0 L --- new connection -------------------------------------------------------- Mon Nov 18 19:40:13 5d:00:26:32.832 01.3 0 L PWD kiwi SND ALLOWED: no user password se…
D11.11 v1.707 Kiwi V2 root@kiwisdr:~/Beagle_SDR_GPS# df -h . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p1 3.5G 2.9G 363M 89% / root@kiwisdr:~/Beagle_SDR_GPS# cd .. root@kiwisdr:~# du 4.0K build.log 4.0K _FLASHED_FROM_SD_ 3…
Debian itself takes up a lot of space, version D8.x took up less than 1.5G, and now it looks like this: clean install Flash D11.9 +v1.690 Kiwi V1 root@kiwisdr:/# df -h . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p1 3.6G 2.3G 1.…
https://forum.kiwisdr.com/index.php?p=/discussion/3415/v1-707#latest
root@kiwisdr:~/Beagle_SDR_GPS# df -h .; journalctl --vacuum-size=10M; df -h . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk1p1 3.5G 2.9G 350M 90% / Vacuuming done, freed 0B of archived journals from /run/log/journal. Vacuuming don…
root@kiwisdr:~/Beagle_SDR_GPS# m clean_logs journalctl --disk-usage Archived and active journals take up 352.0M in the file system. journalctl --vacuum-size=10M Vacuuming done, freed 0B of archived journals from /var/log/journal. Deleted archived jo…
Yesterday I finished updating the last of my five Kiwi v1s, but if someone is as lazy as me and doesn't want to dig the receiver out of the case and disconnect the boards, it can be done, but the condition is to provide an additional 5V power supply…
Kiwi V2 Debian 11.11the message about the available version appeared after 4 clicks, but now I see this: https://forum.kiwisdr.com/uploads/567/FJ8U0UYBBF2S.jpg I'm trying now with Kiwi V1 D11.11 but I'm clicking 9 times and still Git clone damaged!…
hello, today another garbage activation 77.111.244.0/24 91.225.160.0/22 103.135.104.0/24 124.205.128.0/17 Sat Oct 26 10:25:54 12:32:19.364 01.. 1 L PWD kiwi SND ALLOWED: no user password set, so allow connection from 124.205.145.240 Sat Oct 26 10…
Ok, I'll leave it as it is and free one channel to be indexed on the public list, maybe it will be useful someday
https://forum.kiwisdr.com/uploads/627/KS4X4R5FG8PD.jpg You can add your own html code with graphics, it looks like this for me
another Wed Jun 5 05:02:42 1d:07:47:02.896 0123 1 L PWD new connection -------------------------------------------------------- Wed Jun 5 05:02:42 1d:07:47:02.903 0123 1 L PWD kiwi SND ALLOWED: no user password set, so allow connection from …
Now in PL from 160-12m bands closed or barely audible, 11-10m bands 9+20dB signals audible with quadruple echo, FT8 JS8 80% unreadable
This rx.linkfanel list has been showing some miracles for a long time and, as I see it, creates an artificial, unnecessary rat race in which I do not intend to take part, if it is to ensure a good night's sleep for you, I have turned off SNR measure…
I'll let you know in a few hours Yes, everything is fine now, checked on both versions of Kiwi. Thank you.
Nice combo, sorry for the trouble but it wasn't intentional ;) No, the JavaScript was only there
I think it's the fault of my bells and whistles in the other tabs (font styles, highlights, bolds, brands, counter/flag scripts, etc.) all an explosive mixture in my trash bin that I need to clean out. Window content sent to support@
My Kiwi2 also arrived. Thank you. Customs duty in Poland cost EUR 97
BBG and I am sure that I broke it when I forgot to reduce the transmitter power and AGC at the input during the test, I only heard the grating of the distorted RF signal in the headphones. and several hundred W went through the cables, despite dozen…
My Kiwi just died, there is a short circuit, the 501Y choke is getting very hot and it smells of burning. After opening you can see this: https://forum.kiwisdr.com/uploads/031/NNJXQ77NOW05.jpg Now the question: is it enough to pick out the burnt ch…
