ANgazu
- ANgazu
- 8
- 5
No good idea, I presume. Rx keeps in use and computer auto systems do not care about signal. I guess there are better methods to solve this particular case.
Hi. It seems to be LINK 11 CLEW ISB mode. Please, see https://www.sigidwiki.com/wiki/Link-11 for samples. Best regards. ANgazu.
Hello. Yes, Freq is 1000 Hz and time is 1s ON 1s OFF. Do not know where your KiwiSdr is located but the signal seems to be the one by DL2NDO from Germany. ******************************************* From rsgb_lf_group:09 Nov 2018 01:01 "Afte…
Can you, please, check the time pattern? 1s ON 1s OFF? or post a .wav recording instead. Best regards. ANgazu.
Hello. Perhaps yu could try r8brain. https://www.voxengo.com/product/r8brain/ As per http://src.infinitewave.ca/ it performs really well. Batch processing can help in your job. I use it for Sample rate error corrections an results are fine. Best …
