bobby
- bobby
- 9
- 1
How to process an audio data from KiwiSDR on C#?
I resolve it!Uhhhuuu....)
here is my c# code
correct settings
await SendCommand("SET auth t=kiwi p= ");
await SendCommand("SET AR OK in=12000 out=12000");
await SendCommand("SET squelch=0 max=0");
await SendCommand("SET genattn=0");
await SendCommand("SET gen=0 mix=-1");
await SendCommand("SET ident_user=kiwibob");
await SendCommand("SET mod=usb low_cut=0 high_cut=6000 freq=10100.000");
await SendCommand("SET agc=1 hang=0 thresh=-110 slope=6 decay=1000 manGain=50");
await SendCommand("SET compression=0");
await SendCommand("SET keepalive");
code for process byte array, received from KiwiSDR
var buffer = new byte[4096];
while (true)
var result = await socket.ReceiveAsync(new ArraySegment<byte>(buffer), CancellationToken.None);
if (result.MessageType == WebSocketMessageType.Close)
await socket.CloseAsync(WebSocketCloseStatus.NormalClosure, "", CancellationToken.None);
break;
if (result.MessageType == WebSocketMessageType.Binary)
if (Encoding.ASCII.GetString(buffer, 0, 3) == "SND")
int audioLength = result.Count - 16;
if (audioLength <= 0) return;
byte[] audioBytes = new byte[audioLength];
Array.Copy(buffer, 16, audioBytes, 0, audioLength);
// Convert from Big Endian to Little Endian
for (int i = 0; i < audioBytes.Length; i += 2)
byte tmp = audioBytes[i];
audioBytes[i] = audioBytes[i + 1];
audioBytes[i + 1] = tmp;
audioPlayer.provider.AddSamples(audioBytes, 0, audioBytes.Length);
Settings for WaveOut
class KiwiAudioPlayer
public BufferedWaveProvider provider;
private WaveOutEvent waveOut;
public KiwiAudioPlayer()
var waveFormat = new WaveFormat(12000,16, 1); // 12kHz, 16-bit, Mono
provider = new BufferedWaveProvider(waveFormat)
DiscardOnBufferOverflow = true
waveOut = new WaveOutEvent();
waveOut.Init(provider);
waveOut.Play();
public void AddAudioBytes(byte[] audioBytes)
public void Stop()
waveOut?.Stop();
waveOut?.Dispose();
Thank U!
