bytebender
- bytebender
- 111
- 3
W6LVP Amplified Receive-Only Magnetic Loop Antenna / Where to buy in NZ?
I prefer passive over active antenna to reduce failure points and simplify installation. An active loop will also amplify noise in the neighborhood and there is plenty of noise around my location. I have my 303WA-2 mounted on a 6-foot metal pole which is mounted directly onto dirt. I’ve also been experimenting with attaching radials and making the ground more conductive by watering the dirt, which actually seems to improve the signal strength a bit until the dirt dries.
v1.700,701
