WB4klj
WB4klj
494
2
  • CW (morse) decoder extension in KiwiSDR [added in v1.224]
    It seems once I close the extension, it will not reload again. I have to close that browser session and restart another browser session to get it to work.
    73, Bob
  • V 1.395 removing references to sdr.hu
    On the stats tab there is a message saying "Try other kiwis on sdr.hu". I removed this according to jpe's post on Mar 21. Quoted below. Now showing sunrise sunset times.
    "Displaying sunrise and sunset times at your Kiwi QTH in your Kiwi UI
    jpe
    March 21 edited March 21 in KiwiSDR Configuration and Operation
    If you wish to show the sunrise and sunset times at the location of your Kiwi SDR, please remove all code in the “Status” field under the “Webpage” tab in the Admin interface, and replace it with the following HTML code:
    In the example above, the “la” or the LATITUDE parameter in the URL is set to zero, as is the “lo” or the LONGITUDE parameter. You must set them to those of your QTH. Please note that southern latitudes are negative numbers as are western longitudes.
    The sunrise and sunset times are all in UTC
    73 Jari OH6BG "
