36,257
639
  • Default colormap [added in v1.414]
    Okay, added in today's v1.414 release.
    PowernumptyChrisSmolinskiPSO
  • Obtaining date/time from the Kiwi's GPS [fixed in v1.417]
    v1.410,411  October 7, 2020
        GPS time-of-day (TOD) correction now works even if the Kiwi date is set incorrectly.
            Previously the Kiwi week day number had to match GPS for TOD correction to work.
            The GPS code currently does not know how to set the Kiwi date because it does
            not parse the GPS almanac.
    UR5VIBPowernumpty
    UR5VIBPowernumpty
  • Redirect to the next kiwisdr.
    Apparently this happens when the last free slot is trying to occupy 2 users at the same time.
    I'm not sure what you mean exactly. Do you mean when two users are trying to connect simultaneously to the last channel of the first Kiwi in a redirected chain? (e.g. channel #4 of a 4-channel Kiwi1 that re-directs to Kiwi2). The redirection code was tested pretty carefully. But of course that doesn't mean there isn't a bug someplace.
    Also, it would be nice at the time of the update to keep the ability to redirect to the next kiwi instead of the “update” message, if it's real.
    That's an interesting idea. Hadn't occurred to me before.
    WA2ZKDPowernumpty
    WA2ZKDPowernumpty
  • v1.403: colormap improvements, multiple DRM schedule databases
    Alright, something has come up and I'm not going to have time to work on the problems with aperture auto mode for a while. So in today's update I've added an "initial aperture" setting to the admin page config tab:
    v1.409  October 3, 2020
        Added "Initial aperture" setting to admin page config tab. This setting determines
        which waterfall colormap aperture mode, manual or auto, is used as the default for
        "first time" visitors to your Kiwi. More precisely, for any connection to your Kiwi
        where the "last aperture set" cookie has not been previously set ("first time"
        visitors are a subset of that definition).
    ChrisSmolinskirz3dvp
  • Proxy service down or unstable [currently okay]
    @Jimo: Not so simple. Not because of the actual code issues, but because of the validation and deployment issues (as usual). Can you imagine the disruption? Especially if something goes wrong?
    This is probably best handled when there is the eventual need to open a second proxy server (we're getting close and it will probably be in the EU). That way the migration can be done in a controlled way.
    Jimo
  • Any tools to save KiwiSDR waterfall to image ?
    It has a --zoom (-z) option which defaults to zero meaning zoomed all the way out (0 - 30MHz). Setting the frequency only matters when you are zoomed further in (values 1-14). These zoom values match the zoom values seen on the Kiwi user interface (i.e. number 'n' after "WFn" tab on main control panel).
    kovalr
