- jks
- 36,252
- 639
User login to bypass time limits
It will ask after the timeout occurs. This is a problem for people making recordings that don't want the interruption. In that case you can give it in the URL: password=... or pwd=... e.g.the_kiwi:8073/?pwd=...
See the documentation: http://kiwisdr.com/quickstart/index.html#id-user-tune -
Obtaining date/time from the Kiwi's GPS [fixed in v1.417]
v1.417 October 30, 2020 Allow GPS to set date/time. See admin page, GPS tab, new setting on top bar. Defaults to false. Before this can happen the GPS-to-UTC correction must be received from the GPS navigation message stream. This can take from zero to 12.5 minutes depending on the sat page/subframe transmission phase. The date correction has been tested using navigation data streams from Navstar, QZSS and Galileo. Only one date correction is performed per restart. However the previous constant correction of the system time (but not date) whenever it differs more than 2 seconds from GPS time is still in effect. Added FAX extension frequencies for CN stations XSQ and an UNID per forum user Fabrys.
So in the log you might see something like this which shows a date/time update via PRN-N02 (Navstar) from Oct 25 00:01:40 to Oct 30 04:56:07Sun Oct 25 00:01:38 00:01:33.488 .... GPS/UTC +18 sec Sun Oct 25 00:01:40 00:01:35.080 .... L GPS correcting date: PRN-N02 weeks=2129(81+1024*2) weekSec=449767.5 Sun Oct 25 00:01:40 00:01:35.081 .... L GPS correcting date: gps Fri Oct 30 04:56:07 2020 UTC Sun Oct 25 00:01:40 00:01:35.081 .... L GPS correcting date: system Sun Oct 25 00:01:40 2020 UTC Fri Oct 30 04:56:07 00:01:35.089 .... L GPS correcting date: date/time UPDATED -
v1.415 release
v1.415 October 20, 2020 Admin network tab: added Ethernet MTU selection option of 1440 (default 1500) which seems to help some installations using 4G Internet connections. Bug fixes: Well-known DNS server 1.1.1.1 is always added to end of /etc/resolv.conf file. "Photo max height" field can no longer be set blank (which prevented page load). -
v1.415 release
v1.415 release
v1.415 release
v1.415 release
Default colormap [added in v1.414]
Frequency drift
That brings up an interesting point. The Kiwi GPS software lacks most of the features of commercial equivalents, which were developed over many decades now. One of them is masking out sats (i.e. not using them for position/time solutions) if their elevation angle in the sky is too low. There are various reasons this is a good idea as you might imagine. -
Frequency drift
