36,252
639
  • Bent power jack on KiwiSDR board
    Spend a minute or two with an ohmmeter verifying that the replacement is indeed constructed with the same pinout as the original. We know from sad experience that the Beagle & Kiwi don't survive polarity reversal.
    njc
    If there is a manufacturing quality problem then Seeed support should really replace/swap the board. However, the connector you want is called a "DC-044". I found them on Amazon US by searching in the "Industrial & Scientific" category. Example:
    njc
  • v1.419,423: added non-NBFM squelch
    v1.419  November 8, 2020
        Added a simple RSSI-based squelch for the non-NBFM modes.
            See audio tab of control panel. Based on Christoph's squelch from kiwirecorder.
    Don't expect too much from this squelch implementation. It's not a VAD or anything. On the audio tab move the squelch slider fully left to disable (default). Two squelch values are stored separately: one for NBFM and another for all other modes (except DRM which doesn't need it).
    For the non-NBFM squelch the slider represents dB above the median of a number of past RSSI (S-meter) values. There is also a menu of "tail" times -- additional time the squelch is held open before being closed.
    The speaker icon now has a third color, white, indicating the squelch is closed (hence no audio). This in addition to red (muted) and green (squelch open or disabled).
    Powernumptydl7awlWA2ZKDbensonCommSigmaChrisSmolinskinjccathalferris
