36,252
639
  • Flatness of KiwiSDR response < 500 kHz?
    Are you using a window ahead of the FFT?
    It's using a Hanning window now. And the code has the usual suspects available (but commented out): Hamming, Blackman-Harris. I haven't look at the windowing specifically in years. Although we had the recent problems I induced when changing the FFT pixel downsampling and adding CIC filter compensation.
    ka9q
  • Waterfall issue [Android app issue fixed in v1.460]
    If you're talking about the KiwiSDR Android app, then yes, there was a problem that was just fixed. Kiwis that run the latest release (v1.460) or later should work with the app again. About 70% of public Kiwis have updated. The rest should follow in the next day or so.
    The issue was that the app uses an embedded web viewer that did not fully implement web standards that the Kiwi code depends on.
    1Vk3ae0
  • v1.456,458,459
    @HB9TMC I'll fix that today. Shouldn't be applying the CIC compensation when there is no CIC in use! 🙄
    As for the spectrograms, I don't know. All the Kiwi spectrums I looked at using the Kiwi spectrum display and high averaging gave the same peak values on a variety of settings. I guess the only thing to do is make a new waterfall API option so you can select either behavior and Marco can get his fix for SuperSDR.
    HB9TMC
  • Short Circuit SDR - Now Fixed
    They're 0402s, which are stupidly small for hand assembly. If it were me I wouldn't bother. I'd bridge T301 and be done with it.
    njc
  • Is there a way to snap-to-frequency when clicking waterfall? [improved in v1.456]
  • Electric Fence Clicking
    There are two fully adjustable noise blanker algorithms. And they both have an associated test mode, also fully adjustable. So you should be able to practice using them.
    Unless your fence noise is weak or the pulses are not well-defined there shouldn't be a problem. I just tried it again (test mode) and it works great!
    o00scorpion00o
  • firefox last rev gives chopped audio\waterfall on win7pro32b [fixed with browser site data clear]
    I don't think Chome 90 (with the fix) has actually been released yet.
    Given the age of this thread I'm going to un-announce it..
  • BBAI Cannot connect via web browser after build - A little help needed
    Okay, all should be good now (except for my splitting headache). I'm not 100% sure because it won't let me stay logged in for more than a few seconds (BT bastards). And your router isn't forwarding port 8073 connections to the new local ip address of course.
    Sure enough, the Beagle guys made an incompatible change in how the .dtb file is loaded by Uboot. I'll have to figure out a change to support it.
  • KiwiSDR-antenna-switch-extension
    There is a new version of the antenna switch extension available.
    Important installation notes:
    • Let your Kiwi update to v1.449 first.
    • Use my repo, not Kari's, until he merges my changes (e.g. via "gclone" command below).
    • Install can be accomplished from the Kiwi admin page "console tab".
    Get a Linux shell either using the admin page console tab or ssh/PuTTY directly into your Kiwi. Type:
    cd [changes to "/root" directory]
    mv KiwiSDR-antenna-switch-extension K.old [set old copy aside]
    gclone KiwiSDR-antenna-switch-extension [gets new version from github.com]
    cd KiwiSDR-antenna-switch-extension
    bash ./ant-switch-extension-installer
    [pick your switch device from list or "beagle-gpio" if just experimenting]
    [if running from console tab: you'll see a message to that effect]
    [wait a few minutes while build messages scroll by]
    [if running from console tab: it will ask that you restart via the button on the admin control tab]
    New features and fixes:
    • Can limit access three ways: local connections only (owner/admin effectively), local connections plus users connecting with a password (for Kiwis with split user password access), everyone can access. For the split password case you must add "&p" to the URL as described here: http://kiwisdr.com/quickstart/index.html#id-user-urlp-prot
    • Support for KMTronic LAN Ethernet IP 8 channels WEB Relay device. https://info.kmtronic.com/kmtronic-lan-ethernet-ip-8-channels-web-relay-board.html
    • Other user connections are notified via a popup when the antenna is changed. The popup closes automatically after 3 seconds. This may need some refining. There has also been the suggestion that an autoscale be performed on an antenna switch if in auto aperture mode.
    • Message is displayed to user if antenna switch parameters have not yet been configured by admin.
    • Installation time is much faster as entire Kiwi software rebuild is no longer done.
  • v1.443: automatic SNR measurement, queue/camp panel reload button, misc fixes
    v1.449 April 3, 2021
      SNR measurement adjustments on admin page control tab:
        Adjust recording interval: 1, 4, 6 or 24 hours per measurement.
          One week's worth of data is retained in the rolling buffer.
          New JSON field "seq" (incrementing) to help identify most recent entry.
        In addition to existing frequency measurement intervals 0-1800 and 1800-max kHz
          added 0-1800, 1800-10000 10000-20000 and 20000-max
          These are similar to what Marco uses (sibamanna.duckdns.org/sdr_map).
        Selectable local/UTC timestamp.
    benson
