G4DYA
G4DYA
534
4
  • Flatness of KiwiSDR response < 500 kHz?
    I've done some measurements on the frequency response of the Kiwi below 1 MHz. Using a -53 dBm tone (S9+20) from a calibrated signal generator, I got -53 dB on the S meter down to 50 kHz. It rolled off below that:
    20 kHz: -1 dB
    10 kHz: -3 dB
    5 kHz: -7 dB
    HB9TMCka9q
  • Feature Request
    I would like to see a variation where it is possible to clone a complete config *except* the IP address. (Is there even a situation where cloning the complete config *including* the IP address is wanted?) BTW I use static IPs.
  • Combining/Diplexing Antennas to Single Kiwi
    I'm using a diplexer to combine a Wellbrook loop with a 27m horizontal terminated folded dipole (TFD). The crossover frequency is about 1.7 MHz. (I found the TFD marginally better on 1.8 MHz.) The TFD has notches for the 4, 6 and 7 MHz broadcast bands. This feeds an Elad ASA16 distribution amplifier which feeds the Kiwis.
    When doing TDoA, I often find that Martin's RX is the only other one in the UK that can hear what I'm hearing. (It's 50/50 which is best.)
    The main factor affecting performance is neighbour QRM which varies enormously.
    http://kiwisdr.lamont.me.uk:8073/
    I attempted to upload a circuit diagram and a photo, but lost my fight with this forum's software and gave up.
    Richard
  • Kiwi BBAI software Alpha test instructions [updated 3-Jun-21]
    The BB version seems to be over-riding the Kiwi's network settings at boot and using DHCP regardless of whether it's configured for DHCP or static. If you're using a non-NATted static IP this can be very confusing.
    To get a static IP, it's necessary to use connmanctl:
    Find a filename in /var/lib/connman/ starting with "ethernet", e.g ethernet_01234567890ab_cable, then as root:
    connmanctl config ethernet_01234567890ab_cable --ipv4 manual ip_address netmask gateway_ip
    Then add the IP addresses for a couple of your ISP's nameservers:
    connmanctl config ethernet_01234567890abcdef_cable --nameservers 8.8.8.8 4.4.4.4
    I'm attempting to provide cooling for a BBAI in a Seeed case. Without the end plates, two 5V 25mm fans side-by-side works well.
    First, I installed the AI but didn't use star washers next to the board - components are too close for comfort. Instead I used two star washers between the standoffs and the case. I didn't use the nylon standoff at all because there's a chip capacitor very close to the hole.
    Next I stuck two fans to the Kiwi board and connected them to the bottom of the 5v barrel jack. I added a bit of draught excluder to the side of one fan.
    Then connected the Kiwi to the AI.
    Then stuck the lid on. Without anything at the end I held it together with Gaffa tape!
    This arrangement keeps the CPU temperature well below 50° C. With the end plates on, it obstructs the airflow quite badly and is noisy. Next step is to try some sort of mesh grille. After that, I might try some sort of conduction cooling with chunky slabs of copper inside and heatsinks outside.
    Richard G4DYA
    HB9TMCPowernumptyrz3dvp
