n6gn
n6gn
2,511
18
  • Seeed Metal case and GPIO connector
    Martin,
    The mechanism I have observed is in addition to these, looks something like this:
    without perfect balance (infinite CM impedance) at the far end of the (shielded) LAN or PS cable there is *still* ingress at the ADC.
    HB9TMC
  • Anyone using the DX Engineering RF-PRO-1B Active Mag Loop Antenna?
    The splash image on http://n6gn.no-ip.org:8073/ has a schematic of a MW band stop that surpresses MW BCB by about 20 dB and allows for one additional notch elsewhere. This may protect a Kiwi from OV while still allowing only slightly reduced access to stations in MW and good access elsewhere. It can be fabricated from inexpensive SMD components.
    w5pie
  • Possible to pass arguments to an extension using kiwirecorder?
    While " /sys/class/gpio/gpioNN/value" did allow toggling the lines, it seems that it is toggling more than one. I haven't studied the class to understand it and there may be a way around this, however, Gwyn G3ZIL, kindly pointed me to another way that seems to do exactly what I want even more directly. It is:
    rsh root@[kiwi IP address] "/root/extensions/ant_switch/frontend/ant-switch-frontend N;" 2>/dev/null
    where N is the Antenna N selection desired and 2>/dev/null throws away the return text from the BB resulting from the remote shell call. I expect using this method requires compiling the ant_switch extension into the Kiwi but that is well documented and only takes a few minutes.
    This seems to work precisely as hoped and allows setting the GPIO lines of the ant_extension one-at-a-time. I measured 600 ms/setting across my local network.
    If someone simply wants a few control lines to use to programatically control an external device on a kiwi - whether an antenna switch or something else - this seems to be a quick, easy and effective way to do it remotely.
    I've only tested from a remote computer running Ubuntu Linux but perhaps someone more familiar with Windows can provide an equivalent method for that OS.
    See https://github.com/OH1KK/KiwiSDR-antenna-switch-extension/blob/master/docs/antenna-schedules-using-crontab.txt
    for automating this with crontab from the kiwi itself.
  • MIni Enhancement on the new S meter
    Darn, file attach didn't work. Here it is in-line:
    #!/bin/bash
    ### This bash script to sweep a kiwi and report S-meter reading
    ### steps through the set frequencies
    ### and stores the results, timestamped, in a file whose name is passed as an argument when calling the script
    ### Dependencies: Needs kiwiclient directory with kiwirecorder.py
    ### Version 1.0 May 2019 Script from Gwyn Griffiths G3ZIL hacked for WB7ABP by N6GN
    ### Version 1.1 throw away initial measurement after frequency (or other?) change. It's bogus. Remove delays
    #if [$# lt 1]
    # then
    # echo "no argument"
    #fi
    #3echo "This script needs a single argument, the output file name with a csv extension, e.g. test_22_May_2019.csv"
    VERBOSITY=1 # set 1 for test mode, otherwise 0
    # say where kiwirecorder is on this host
    KR='python /home/ge/kr_test/kiwiclient-master/kiwirecorder.py'
    # set the start, stop and increments for the test frequencies, could also be an array e.g. for wspr bands, revisit
    START=12000
    INC=50
    STOP=16000
    # quiet ? spots
    LIST="60 400 560 600 760 1060 1360 2500 5000 10000 15000 20000 25000 28000 29950"
    #LIST={$START..$STOP..$INC}
    # one frequency point with 2 averages takes about 1 sec, 10 averages ~2 sec and 100 takes ~20 seconds.
    AVERAGES=10
    # target KiwiSDR
    HOST=10.0.0.77
    PORT=8074
    # write header to the csv file, with names on one line, units on the other
    DATE=`date --utc "+%Y/%m/%d %H:%M"`
    echo "Measuring, $HOST, $PORT, on, $DATE" >> $1
    echo " Frequency, S Meter" >> $1
    echo " kHz, dBm " >> $1
    #for i in `seq $START $INC $STOP`
    for i in $LIST
    do
    echo "acquire data for $i kHz"
    # set to 10kHz bandwidth
    OFF=`$KR -s $HOST -p $PORT -f $i m iq -L -5000 -H 5000 --s-meter 1` # discard, first reading is bogus !!!!
    OFF=`$KR -s $HOST -p $PORT -f $i m iq -L -5000 -H 5000 --s-meter $AVERAGES`
    # strip off the leading "RSSI:"
    Smeter=$(awk -F: '$0=$2' <<<"$OFF")
    if [ $VERBOSITY == "1" ]; then
    echo "Level was $Smeter dBm"
    fi
    # write data to the file
    # get the date and time in UTC
    # DATE=`date --utc "+%Y/%m/%d %H:%M"`
    # echo "$DATE,$i,$Smeter" >> $1
    echo "$i,$Smeter" >> $1
    done
    echo "Finished sweep"
    echo $LIST
    While it's being tweaked, an option for markers out to 1/hour or less frequent would be great.
    It's fascinating to watch thunderstorm level and perhaps even galactic center noise floors!
    HB9TMC
