- jks
- 14,113
- 120
In stock again at WiMo (DE).
Beginning with v1.436 the band identifiers will not be displayed if their frequency is less than the frequency scale offset. But the remaining empty white space is not reclaimed because right now that is difficult to do (for historical reasons). It …
The three new USA/Canada distributors (that have the metal enclosure in stock) now claim to have quantity 2 of the full kit in stock at an excellent price with free USA shipping. See links on kiwisdr.com (Online Components, Master Electronics, Elect…
The Kiwi all-inclusive version ($299 USD) is back in stock on Seeed's website: https://www.seeedstudio.com/catalogsearch/result/index/?q=kiwisdr I would not recommend using the less expensive postal delivery option given the poor state of internatio…
Next time this happens, note the state of the single blue LED to the "right" of the Ethernet RJ45 (other side compared to the four status LEDs). If it's OFF then there has been a power quality event such that the Beagle's power management …
Use of the plastic washer is not critical. It just helps the plastic standoff match the height of the metal standoffs with their associated star washers. What is critical is placing the plastic standoff at the correct location so the traces to the s…
Are you using the correctly sized 5V plug at the Kiwi power connector? If not, and the 5V cable is subject to being moved slightly by the wind, then this would explain the problem. We had someone complain about this exact issue a while back and it i…
I haven't tried this myself in a long time. But our documentation has some instructions here: http://kiwisdr.com/quickstart/index.html#id-net-p2p But there is also a note there that it doesn't work with Windows 10 anymore. Can anyone verify? Does an…
v1.433 February 12, 2021 Timecode extension improvements: Support for JJY(Japan), RBU(Moscow), RTZ(Irkutsk), BPC(China) added. While running AGC delay is temporarily increased to improve noise immunity.
Yes, Octopart now says the same thing. Strange. It's almost like stock is stuck in the shipping black hole for months at a time 😕
I don't get any royalty off the metal enclosure. That's strictly Seeed's gig. So if someone wants to step in and better meet the demand that would be fine with me since Seeed is doing such a marginal job of keeping them in stock. I don't know if it …
Distributor stock quote systems seem to be as broken as international shipping. Seeed is on Spring Festival for another week so I won't be able to ask what the status is with the metal enclosures. I don't know of any specific problems, except that i…
On the server side there is a fixed limit of 256 characters for the name/callsign field. This limit is enforced by truncation. But if the field contains Unicode characters it is possible to end up with a truncated multi-byte Unicode sequence. This s…
Mouser now has the board version ($199) in stock.
In the case of the BBAI: https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#i_take_full_responsibility_for_knowing_my_beagle_is_now_insecure
Feb 2021: Alpha "Khabarovsk" (nearest town Elban) as received from the Kiwi in Khabarovsk about 200 km distant. MSK signals VTX3 India and NWC Australia also present. http://forum.kiwisdr.com/uploads/572/DEL2GFTLJUCT.png
See second section of admin "config" tab. All configuration files can be cloned from another Kiwi or just the dx (aka label, tags) file. Maybe you had a variation of this feature in mind?
I never tested the backup function on the AI. It's possible the script doesn't work since the AI runs Debian 9 instead of Debian 8 like most Kiwis.
In v1.431 you can specify the name/callsign in the URL, e.g. "my_kiwi:8073/?u=my name" "user=..." also works. With narrow screens sections of the top bar are removed from display. First the time/OpenWebRX section on the far right…
I'm not an expert, but I think the short answer is no. Forgetting about GPS time-stamping of the IQ samples for the moment, one thing the GPS does is correct for any error in the ADC clock. Improving the characteristics of that clock doesn't really …
Seeed has a few of the metal enclosures in stock again. There are more of the complete "kit" versions (MSPR $299) in production, but there are parts procurement issues and shipping delays. If in the Americas your best bet is to order from …
Thanks for pointing out that Chuck is running RaspPIs (I checked, he has one that is public and no KiwiSDRs). So Chuck is no longer with us. He can use the RaspPi forum for his questions.
Anything new about this? Could it be related to the Comcast/Xfinity problem others have had recently?
Okay, so you're already using DDNS. And I see you've publicly registered your Kiwi. Public registration causes a ping to be sent to kiwisdr.com every 20 minutes (last seen Jan 30 23:58 UTC). I would have thought this would have been enough activity …
Yes, question is too short to understand exactly what is being talked about. But to me it sounds like it's the local (private) ip address that the router is moving around for some reason. E.g. you y initialldiscover it's 192.168.1.101 and make a con…
If you know what was done to fix this please let us know. It's valuable to add this to the list of known problems/solutions.
Given this seems to be in your router, and Comcast is involved, I would try this: http://forum.kiwisdr.com/discussion/comment/9770/#Comment_9770
No, it's up. Where are you? Someone in Europe had this problem a few days ago and it cleared up after a few hours. ISP routing problem.
As noted on the kiwisdr.com page there are three new distributors in the USA and Canada who claim to have stock of the metal enclosures. Everyone else, including Seeed, is out-of-stock. But we have never heard of these distributors before and have n…
@KB8DOA This morning (19 Jan 2021) R&S shows 13 Kiwi kits in stock. Please get on them immediately and make sure your two backordered units from last July get shipped so this awful situation can finally be resolved. My sincere apologies for thi…
