ArturPL
ArturPL
666
3
  • After downloading 1.463, the receiver broke down completely. I can log in to the admin panel, but all tabs are completely empty. The Kiwi page fires up but only a photo is displayed, the drop down bar has expanded to halfway, no waterfall, no clock.…
  • Hi SNR reports are often exaggerated, and in my location where background noise is very annoying, I used multiple antennas. The best result was on a Delta antenna suspended at 10m, where after using bandpass filters and a 3-10MHz preamplifier, cutti…
  • I did a 12 hour test with 20MHz spectrum masking and actually the linkfanel map doesn't update that. It still says Blocked spectrum: 10.7% and the only change is next to the timeout icon ⏳, adding the icon 🚫. The case is cleared.
  • Hello I managed to clone the lan so I don't complain. In the future, you will have to connect a new device next to it and import the bookmarks, and then install it elsewhere and apply any changes manually. Most importantly, I have to go out to the w…
  • And for the more lazy you can create a DX label on the band you are interested in. You set the frequency, the type of modulation and in the Passband window for the LSB you set -3000, 0 and for USB 0, 3000 you add to active and you have a 3kHz ready …
  • From my own experience I know that two antennas, and in my case three :) can be adapted to improve the signals. I don't know what antennas you want to use, but at home I adjusted the mini whip, delta and vertical stick so that the signals from one d…
  • In my case, out of 3 KiwiSDRs I purchased, two of them had a problem with the original card. An oxidized layer of white coating has formed on the contacts, which must be removed mechanically using, for example, a 0.5mm precision screwdriver. A few s…
  • A properly grounded mini whip also works, mine hangs on a fiberglass telescope 15m from the ground and over 5 from the roof. http://forum.kiwisdr.com/uploads/333/H6E1KV70I5HV.jpg
  • I had a similar case in August. On both receivers I only received one gps signal, which was very weak. Everything returned to normal by itself after 3-4 hours. Antennas glued to a metal roof 10m above the ground. In my opinion, it was either due to …
  • Is it possible to add in the Config tab the settings for WF ceil / floor in Aperture Auto mode to start with 0dB values? The waterfall then looks much better than the default ceil + 5dB / floor -10dB greetings Artur
  • Additionally, shielded RJ45 cable with CAT.6 standard or better, with which you connect Kiwi and router + its grounding, and no more Ethetnet noise. But remember that if you also ground the power supply from the same point, the effect will be opposi…
  • Thanks for the quick fix, it works fine.
  • Great job with that lockout. I know there was already a thread asking for the ability to block IQ or Comp, but another nice option would be to have as default the Audio filters with std-wdsp-75us settings set by the administrator just like the defau…
  • I use efficient thermopad on all heating elements instead of the fan and everything works stably
  • Phil If you haven't managed to make a backup of sdr.hu, as probably most people, then use https://web.archive.org/ mark the date before closing the project and it's ready, I checked it works. There is also the https://www.receiverbook.de/ project w…
  • Hello I will add that the same effect causes NO error in html, only incorrect entry by the administrator in the Config tab, if in the "Waterfall min (dBFS, fully zoomed-out)" window you enter the same or higher value as in the "Waterf…
  • Good morning I am getting another new signal from China best regards Artur (Image)
    in DRM Heard Comment by ArturPL August 2020
