G4DYA
G4DYA
634
4
  • GPS antenna alternatives
    This is what my shadow map looks like after 18 hours. As expected, there's not much low-elevation stuff in some directions because of trees. In other directions, where the optical horizon is 20+ km away, satellites are being received at elevations as low as 3°. The 'polar hole' is clearly visible.
    M0TAZ
    Just to add to this dormant thread, yesterday I installed a PCTEL GPS-TMG-40N antenna with low-loss feeder and it certainly does the trick. I went for the 40 dB version so there's plenty of signal in hand to feed a 4-way passive splitter when I get one. I'm somewhat screened by tall trees in the south-west quadrant, so don't get many low-elevation signals from there.
    The KiwiSDR GPS software only seems to allow a maximum of four Galileo satellites in the 12 channels. Is this intentional? While it all works fine, it would be nice if the limit could be raised - either by allowing more than four Galileo sats, or by allowing more than 12 channels. Also, surely there isn't much point in scanning for QRZZ satellites in Region 1?
    WA2ZKDPowernumpty
    WA2ZKDPowernumpty
