W1EUJ
W1EUJ
821
14
  • Automated Screenshots
    A couple things. One is that on Firefox, the spacing of the checkboxes is a bit off. Second is that the saved file name could use a timestamp added to it.
    I'm going to leave this running for a while.
    VE3SUN
  • Best Stations for TDoA
    Playing TDoA golf. WA2ZKD, W1EUJ and K1RA on WCBS gets me about 4 miles away from the transmitter, on the GW Bridge.
    Edit: Yes - WA2ZKD. The Linchpin on Lake Ontario.
  • Using WSPR to evaluate your station
    Well, I must be doing pretty well! 20 Meter all spot totalled 2100 in 12 hours.
  • New User - thoughts / issues
    To your point 6 - Mine are here: https://github.com/ringof/kiwi-dx.json
    Lonecrow
    My tags are selected for most casual users to be able to do something with it - I don't like TOO many tags up there, just the once likely to get some attention. Most of those FSK stations are encrypted and doing things like TDoA on them wasn't something I saw many folks do. For the few stations you can do something with, they are already on the dropdowns for the FSK/NAVTEX extensions and they decode fine. I will go and add the NAVTEX from Boston though.
    Lonecrow
  • W/F and SND Bad Params
    I did the following - make a rule to both log and drop it:
    iptables -N LOG_DROP
    iptables -A LOG_DROP -j LOG --log-prefix "INPUT:DROP: " --log-level 6
    iptables -A LOG_DROP -j DROP
    iptables -I INPUT -s 47.88.219.0/24 -j LOG_DROP
    then make those rules persistent:
    sudo apt install iptables-persistent
    OR if this package was already installed:
    iptables-save > /etc/iptables/rules.v4
    You can check on the attempts by:
    dmesg | grep INPUT:DROP | tail -10
    and adjust the number at the end for the number of line items you'd like listed; 10 fits within the admin console window.
    VK3KHZ
