v1.464: Workaround for Kiwis using Unicode (UTF-8) in configuration description fields
jksjks
edited September 14 in KiwiSDR Discussion
From the CHANGE_LOG file:
v1.464 September 15, 2021
v1.463 introduced a bug whereby if a Kiwi has been configured with Unicode UTF-8 character
sequences in the various description fields (e.g. receiver name, location, antenna or the
additional HTML field) then those UTF-8 sequences may have become corrupted in the
configuration files (kiwi.config/{kiwi,dx}.json)
  There are several consequences of this bug in v1.463:
  1) The admin page may only show the title tabs and nothing else
(i.e. remainder of page fails to load).
  2) The Unicode replacement character
en.wikipedia.org/wiki/Specials_(Unicode_block)#Replacement_character
    (the '?' character inside a black diamond) will appear in place of the broken UTF-8 sequences.
    These replacements will appear on the page when connecting normally to the Kiwi and also
on the various listing site (e.g. rx.kiwisdr.com) where the description fields are used.
  v1.464 has a workaround for this problem. The broken UTF-8 sequences in the configuration files
  will be replaced with the ASCII '?' character at Kiwi server startup time. This should allow the
  admin page to load. However, the Kiwi owner/admin will have to manually re-enter the desired
Unicode characters as the bug caused the original Unicode to be lost.
We apologize for this inconvenience.
  If the Kiwi has automatic updates disabled there is obviously going to be a problem since the
  admin page may not load so that an update may be started. An alternative is to ssh/PuTTY directly
into the Kiwi Beagle and update via Debian shell commands. If this is not possible there is also a
hack to force an update even from the partially loaded admin page.
Please email support@kiwisdr.com or ask on forum.kiwisdr.com for details about this method.
  Use floats instead of doubles in the ALE 2G extension.
  • Thanks John, the ADMIN page on all of my Kiwi's are now working fine !
    Kind Regards
    Paul
