v1.437 From Marco, IS0KYB: AGC threshold bar, Passband overload mute
From the CHANGE_LOG file:
v1.437 March 6, 2021
  From Marco, IS0KYB (thanks Marco!)
    AGC threshold bar added to S-meter:
      The white bar appearing above the green S-meter bar is the AGC threshold value
      (from control panel AGC tab). The threshold dBm value can read on the
      S-meter scale in equivalent S-units.
    Passband overload mute:
      Mutes the audio when the signal level in the passband exceeds a set value.
      The value is defined by a new setting on the admin page config tab.
      When active a "!" appears in place of the mute icon on main control panel.
      Useful for example when a nearby transmitter would otherwise result in a
      loud annoying signal. Mute recovery time uses existing squelch tail setting.
  Added list of code contributors to _COPYRIGHT file.
    Work in progress. If we missed your code contribution please email us.
    We have hundreds of github issues and thousands of emails and forum posts to review.
  Typing '/' alone into frequency box will restore the passband to the default value
    for the current mode. Shortcut to shift-clicking over a mode button.
  FFT extension: add help button, URL parameters, preset for RTZ.
  Add mouseover popups to more buttons and menus on main control panel.
  Removed more references to sdr.hu
HB9TMCBruiserbenson
  • The white bar in the S-meter is a very nice addition to keep track of the AGC setting. I really like that as it is a great reminder of where the AGC is set. It doesn't zero out when AGC is off and Manual is being used. Not a big deal, but worth the mention, I think.
  • I too like it, even if only as a reminder.
