Help with making a copy of security on sd card
Im Needs step-by-step help to make a backup on sd card
thank you Marek
    edited August 2017
    Hi Marek,
    1. Insert a 4GB or larger micro-SD card into Beagle.
    2. With your browser connect to the admin page of your Kiwi: url_to_the_kiwi/admin (e.g. kiwisdr.local:8073/admin)
    3. Click on the "backup" tab on the top navigation bar.
    4. Click on the button labeled "Click to write micro-SD card"
    5. Backup process will take 3 - 6 minutes depending on the speed of your SD card.
    6. IMPORTANT: remove SD card immediately from Beagle. Otherwise on next Kiwi reboot it will be restored from the SD backup.
  • Hi John and others,
    Simple question - When removing an SD card, is it safe to do it with power on?
    I realize inserting the SD card must be with power on otherwise the system would try to boot from the SD.
    Gary in Vancouver, BC
    edited August 2017
    Yes, the driver in Debian Linux understands how to deal with live insertions of cards in the SD slot.
  • edited August 2017
    HI at point_6 JKS says: remove immediately .
    I suppose that there is a running bar during the writing precedure , but how to be sure about the END_OF_PROCEDURE so one can remove the micro_sd safely?
    Any suggestion howto insert\remove the micro_sd by fat fingers in such tiny place ?
    a plastic extension glued maybe ?
    Could be possibile to cut a hole on the card back to put a fishing line to make removing simpler  :-O
    Phil
  • A message is displayed telling you if the backup was successful or not.
    Try doing a backup without a card inserted to see..
    OK about the end-of-procedure message, but in how long time the BEAGLE restarts?
    Maybe a PAUSE button will be ok to be pressed when one has pulled out the sd-card.
    Would it not be more practical to make a copy directrly on a usb-memory as its plug is more easy to be accessed ?
    Phil
