KiwiSDR-antenna-switch-extension
could someone write me step by step how to install KiwiSDR-antenna-switch-extension ?? unfortunately I'm not fluent in Linux and I don't know how to do it, I found a repo on github but I don't know how to do it....
cd /root
git clone https://github.com/OH1KK/KiwiSDR-antenna-switch-extension.git
cd KiwiSDR-antenna-switch-extension
bash ./ant-switch-extension-installer
You need to open a terminal window (using putty for example), log in as user debian and password is your kiwi's serial, and execute the commands above line by line.
What hardware do you want to use?
Eckhard
I try to install by Console on the webrowser...can you do that?
http://forum.kiwisdr.com/discussion/1801/v1-354-security-improvements-debian-root-password-no-longer-unset-blank
There is a new version of the antenna switch extension available.
Important installation notes:
Get a Linux shell either using the admin page console tab or ssh/PuTTY directly into your Kiwi. Type:
cd [changes to "/root" directory]
mv KiwiSDR-antenna-switch-extension K.old [set old copy aside]
gclone KiwiSDR-antenna-switch-extension [gets new version from github.com]
[pick your switch device from list or "beagle-gpio" if just experimenting]
[if running from console tab: you'll see a message to that effect]
[wait a few minutes while build messages scroll by]
[if running from console tab: it will ask that you restart via the button on the admin control tab]
New features and fixes:
Works here....
My local club uses ant-switch to select their 2m converter. I will see what they think of this method of stopping random users switching back to HF.
