Kiwi phase/frequency stability & Ebnaut decoding
edited December 2019 in KiwiSDR Discussion
This discussion was created from comments split from: offset for vhf wspr decode.
  • Does anybody have data on the stability of the frequency/phase of the kiwi? I tried to decode Ebnaut (coherent PSK on VLF/LF) without success so far, but yet without a good SNR signal source.
  • edited December 2019
    Stefan, perhaps a new topic on the subject of Ebnaut decoding?
    I have also tried without success - perhaps due to incorrect post-processing of the output audio file.
    http://abelian.org/ebnaut/software_linux.shtml
    @HB9TMC
    I haven't documented the kiwiSDR onboard GPS performance but I have examined it, particularly in comparison to use of the Kiwi with an external clock. You can do the same by comparing two of my kiwis, one with a Bodnar GPSDO which generally appears to be better than 1 ppb and to not limit the phase noise performance of the kiwi with another using the on-board GPS reference.
    Bodnar referenced Kiwi
    and
    on-board kiwi GPS
    are both looking at US NIST LOS/"groundwave" signals transmitted from less than 20 km distant.
    This may not be entirely satisfactory since the on-board kiwi's GPS antenna is outdoors but not very well located.
    HB9TMC
  • Thanks for the links with the comparison. Although the external reference is clearly better, I think considering the low frequency used for EbNaut, phase stability/noise it isn't a problem. But I haven't done the math.
    A known problem at receiving EbNaut with the kiwi (at least on my side) is the lack of timestamps. I think kiwiclient would support timestamps, We only have to get them to the vlfrx-tools somehow. Did you compensate the buffer delay during your attempt @G0LUJ ?
  • I ran into the timestamps issue as well and could not get a correct delay value. I moved on to other modes, but I still retain an interest in receiving EbNaut with the KiwiSDR if it is possible.
    Kiwi TDoA certainly works using the timestamps embedded in the .wav file recorded by kiwirecorder when the "-w" or "-kiwi_wav" argument is used (IQ mode files only).
    There is some example code in kiwi/wavreader.py of the kiwiclient repo that shows how to extract the timestamp info from the .wav file.
    G0LUJWA2ZKD
