Static address in admin network not working, but will dhcp.
While playing around with cables and Ethernet speeds on the latest software version I have got it into a strange condition.
I can't see/ping the Kiwi on the network at the defined static address (which has been static and working for ages) but I can put it on another network and it will pick up an address from DHCP.
I've rebooted everything in line between the Kiwi and router and the kiwi a few times swapped cables and ports.
I got in via SSH renamed opt.admin_ip so I can use the web interface, set it to DHCP and rebooted (connecting back to orginal network)
On the original network, I saw it get the right dhcp address from the router, respond to three pings from a constant ping running, then nothing.
Feels like it is pushing traffic the wrong way once up?
  • edited August 2019
    OK I might be over complicating this, might just be "DHCP enabled all the time", not respecting the admin interface static address.
    The rest (uncontactable) might be just a local issue with a rogue DHCP server.
