Running multiple Kiwi's and sdr.hu
I thought I'd throw my other Kiwi online to compare antennas and noise reduction efforts over time.
I had a rough idea from previous posts but I found it quite hard to find a concise guide using site and forum search (do you reuse the API key? just add the second one on the admin/connect section etc.).
Is it worth putting an entry in the getting started for multiple Kiwi's?
I did reuse the API key as found that in a previous post but had forgotten where the "Next Kiwi URL redirect" entry was added if I wanted to go that route.
I went with the API so it would hopefully get logged on http://sibamanna.duckdns.org/sdr_map.html and this latest antenna build and orientation could be compared to the previous.
