60 Meters interesting utility signal?
edited July 2018 in Signals Received
Not spotted this before, centred around 5.412 MHz.
The audio clip is here, with a CW ident I think.
https://drive.google.com/file/d/1mpuwqdVpbI1rZt2FMTc_pwvtaPdTWIS7/view?usp=sharing
It later turned into a FSK signal, same freq no pause.
The TDoA showed an interesting thing...
Any suggestions..
Dave
http://forum.kiwisdr.com/uploads/Uploader/49/f53d200e89443a3da4af98fee9c519.jpg
http://forum.kiwisdr.com/uploads/Uploader/5f/877067d346d29e71f38ef61e0e96ee.jpg
http://forum.kiwisdr.com/uploads/Uploader/65/c767fe5c49bcce4f5ab73406733d78.jpg
    edited July 2018
    Sounds like the marine SITOR station channel markers, e.g. TAH:
  • Hi Dave,
    It's a fairly popular frequency, particularly with the Russians, and it could be that you are hearing (and trying to TDoA) a mix of transmissions emanating from more than one source at the same time.
    I'd suggest you join the utility monitors on UDXF@groups.io and take a look at the monthly logs in their files section.
  • Forgot to add.
    This was previously mentioned in the TDoA success thread.
    I found a FSK signal with 500Hz shift on 12183KHz USB which I think comes from Istra near Moscow 55.884167, 36.953611
    So this is pretty close to your TDoA plot too.
