KiwiSDR Discussion
Installation, Antennas and Interference
Quick Links
Categories
Recent Discussions
Categories
1.4K
All Categories
46
KiwiSDR Discussion
10
Configuration and Operation
7
3
WSPR, wsprdaemon, kiwirecorder
BeagleBone AI
1
TDoA topics
3
Signals Received
5
Problems and Issues
7
Problems Now Fixed
4
General Chat
1
2
3
4
5
Discussion List
Wideband noise around 1.6 MHz
160
views
16
comments
0
points
Most recent by
la3rk
December 2020
Help with local interference
100
views
7
comments
0
points
Most recent by
K7GFH
December 2020
Two antennas on my Kiwi SDR
139
views
8
comments
0
points
Most recent by
December 2020
Keep your ground connections short if you want them to work
148
views
6
comments
1
point
Most recent by
johnk5mo
December 2020
Variable power supply voltage setting.
57
views
3
comments
0
points
Most recent by
hobergenix
December 2020
F****r! QRM (not rude btw)
296
views
13
comments
1
point
Most recent by
December 2020
Antenna switch extension: should antenna change trigger WF autoscale?
36
views
0
comments
0
points
Started by
dl7awl
November 2020
Interference -advice
150
views
9
comments
0
points
Most recent by
ArturPL
November 2020
Ultimate Ferrite Solution
881
views
12
comments
0
points
Most recent by
October 2020
Problem with massive RFI after changing router
279
views
20
comments
0
points
Most recent by
MelliLewis
October 2020
US$1 5VDC Power Supply for the Kiwi
393
views
6
comments
0
points
Most recent by
Jacques7
September 2020
request for background noise information
171
views
11
comments
0
points
Most recent by
fabrys
September 2020
IP connection to Kiwi through Kiwi's USB interface
58
views
1
comment
0
points
Most recent by
rrobinet
September 2020
DX-Commander all-band vertical; anyone else using one?
130
views
1
comment
1
point
Most recent by
alinton
August 2020
TX near the kiwi
170
views
6
comments
0
points
Most recent by
n6gn
August 2020
Combining/Diplexing Antennas to Single Kiwi
1.4K
views
54
comments
0
points
Most recent by
cathalferris
August 2020
KiwiSDR + MLA-30
252
views
5
comments
0
points
Most recent by
G0LUJ
July 2020
2.6K
views
58
comments
0
points
Most recent by
Tony1951
July 2020
Linear power supply for KiwiSDR & others, fan cooling
152
views
4
comments
0
points
Most recent by
ChrisSmolinski
June 2020
A tip for the KiwiSDR GPS antenna installation.
298
views
11
comments
0
points
Most recent by
Christoph
May 2020
Power over Ethernet
95
views
2
comments
0
points
Most recent by
May 2020
Beaglebone Black with Radio Cape
122
views
6
comments
0
points
Most recent by
May 2020
Anybody seen such multiple signals before?
118
views
1
comment
0
points
Most recent by
cathalferris
April 2020
Multiple Kiwis, single GPS antenna?
160
views
6
comments
0
points
Most recent by
April 2020
GPS Distro Peril
54
views
0
comments
0
points
Started by
April 2020
Wellgood balanced loop amplifier, (Wellbrook clone).
5K
views
25
comments
1
point
Most recent by
March 2020
Active Dipole
178
views
2
comments
0
points
Most recent by
UR5VIB
March 2020
Broadband antenna with gain on high bands
371
views
20
comments
5
points
Most recent by
Ulli
February 2020
KiwiSDR supplier
197
views
7
comments
0
points
Most recent by
ChrisSmolinski
February 2020
KiwiSDR-antenna-switch-extension
150
views
4
comments
0
points
Most recent by
SQ8J
February 2020
1
2
3
4
5
