Keep your ground connections short if you want them to work
Earlier today I got an email from an SWL with a KiwiSDR & AirSpyHF+. He was complaining about very high noise / RFI levels, even though he lives in a rural area much like myself (he was comparing his noise levels to what he sees when using one of my online KiwiSDR receivers).
We exchanged a few emails back and forth, so I could understand his setup. He has a 80 ft T2FD and 500 ft sky loop antenna, so comparable to some of my antennas. I asked him if the coax shields were grounded, he said yes. OK, I asked how.
"I have a very nice ground it is a 8-ft rod into the ground and it is connected with the 12 gauge copper wire to the coax cables."
I explained that the connection from the ground rod to coax shield needs to be as short as possible. Ideally a few inches. How long is it? If it is many feet long, the inductance will be high, and it will not work as a good ground connection.
"Apx 12 feet".
Hmm... So he shortened that to 9 inches, and reported the RFI levels dropped down to as low as if no antenna was connected to the radio. Ideal background noise levels.
He was pretty happy 😀
So the moral of the story is, if you want your ground to work, you need to keep the connection to it as short and low inductance as possible.
  • I made some simple brackets that clamp to the ground rod and have 3/8" holes. I put "F" bulkhead barrels in the holes and that becomes a splice point, ground point, a bit of a lightning arrestor point. The ground is zero length.
  • I do nearly the same thing, I got a bunch of CATV F connector grounding blocks off eBay, attached directly to my ground rods. Short, direct, and low impedance.
  • I had grounding blocks and they weren't reliable outside, so I switched to the bulkheads, cheaper too
